Does this ls1 seem sluggish to you? [Vid inside]
I was watching videos on youtube of camaro and FB runs. This video resembles about how fast mine is. Is it just me but compared to the other near stock ls1 videos doesn't this seem slower than average?
http://www.youtube.com/watch?feature...&v=JJNXnKgk6mE
it only seems sluggish because of the 2.73's you have to understand that the ls1 doesnt make huge torque, so highway gears like that are useless. now if it had a 408 then that would be a different story.
OP, I say get some 373's and take another Vid.
That car seemed pretty healthy to me. i guess its hard to tell how fast it is if your not in it or watching any track times but i thought it was good. i would try changing the gears in your car, should help alot.
Any way to tell between 2.73s and 3.23 without pulling the cover and counting teeth?
Can I turn the wheel 1 full time and count how many times the drive shaft spins, approximately?
Check RPO codes (lt1 was in glovebox, ls1 on the drivers door?)
Code starts with a GU
GU5 is 3.23
GU2 is 2.73
Rest of codes can be found here
http://www.myls1.com/howto/rpocodes/rpo_codes.pdf
GU5 is 3.23
GU2 is 2.73
GU5 is 3.23
GU2 is 2.73
GU5 is 3.23
GU2 is 2.73
I'm on my phone so I can't search for this: will a stock rear end from an M6 be compatible with an A4 that had 2.73's? I'm pretty sure the carrier is different, can you just pull that too and swap it?
