Ls1 heads on a 5.3?
Thanks for the replies. I continued researching after I posted that question and found out all gen 3 heads are interchangeable. I guess the next question is more involved.
I want to install a 5.3 in my 1970 camaro. I have a set of 241 heads. I know now that simply installing these heads will drop compression a bit. (not sure how much). I also know using pistons from a 4.8 will bring it back up.
Is the drop in comp from the 241 heads enough to warrant replacing the stock 5.3 pistons with the 4.8s?
The plan for the engine is a cam upgrade, ls1 intake, and moderate overall performance improvement.
^ Revise that. Did some research. The 4.8 pistons are the same diameter but the crank stroke is different. I think you will be ok as long as you take into account the difference in piston type between the two engines. And remember that the 5.3 has a total of .352 inches more stroke which equates to .176 inches higher at TDC. As long as you make sure you have proper PTV clearance, you will be ok running the 4.8 pistons.
So considering the parts I have, or will have soon. A stock 5.3 iron longblock a set of 241 heads. Would you use the 5.3 heads or the 241 heads?
Maybe this is a better question, with the items above as a base, how would you build this 5.3? Street driven, auto cross, possibly open track events once or twice.
1970 camaro, manual trans, built to handle a road course. But mainly used for street fun.
I'd like to keep the efi.
What intake, cam, which heads from above, which injectors,
Would you change anything away from stock in the bottom end? Oil pump, bearings, rings, 4.8 pistons for better compression?
This will be my first ls build. Idle quality can be rough. But driveability should be good. No power adders,
Last part of this is that I really want to use as many factory GM parts as possible.
I'd love to hear opinions on this. Thanks!
I have not decided on a gasket yet. It's going to depend on the condition of the shortblock I end up with. If I need to go through it I will swap the pistons. If not then maybe mill the heads. I still need to choose a cam, intake and TB.
Fantastic info! Thank you very much.
I will look into the heads and intake and cam.
You mention truck headers, are they made just for the 5.3 heads? Or for a truck chassis? (the engine will be in a 1970 Camaro).
You know what, I forgot you were transplanting the engine. The ones I mentioned are for the truck chassis. You will need ls style headers built for your year of camaro. There are a lot of companies that do swap headers as well as standard ones. Look around on the internet a bit and see what you can find. I'll look around too and let you know what I find.
I'm also doing a build of a 5.3, and I'll be putting mine in a 67 Camaro. So I've been researching ways to build it on a budget. From what I've read, the 5.3 heads flow as good or better than LS1 heads. So with some porting, you can get better performance and not have to buy another set of heads. I didn't know about the difference between the 4.8 and 5.3 pistons - thanks for the info. I may use 4.8 pistons in mine if PTV clearance is good. For a cam, I'm going to use a z06. Nothing as aggressive as a lot of the guys on here use, but should be a decent cruiser. I also picked up a used LS1 intake, but still keeping an eye out for an LS6. Like you, I'm trying to use oem parts. And I'm trying to keep the cost down, so I'm constantly on the hunt for good used parts. You mention a manual trans in the Camaro. Is it going to be an old 4 speed or a t56?
pd
pd
There was a great build on a carb.'d 5.3 in camaro performers, chevy high performance or super chevy mag. I need to find it.
Anyway,.they used the 4.8 factory pistons which have coated skirts to bump the comp up a bit. With a ls1 carb. intake, trick flow heads and a small cam they hit over 490 hp.
I'm going a little different on mine. Ls1 heads, ls6 intake, moderate cam, 4.8 pistons, stock bottom end, not sure what TB yet, although I have a brand new one from a l92 but have no idea if it will fit. If not it's going up for sale.
When I find that article I'll get in touch and get you the details.
There is no reason I need to go aftermarket anything on this. I know I can build a decent, reliable and strong street motor with factory parts. Plus if anything ever breaks or wears out I can find parts everywhere easily.
I'm not sure on the trans. Maybe a tko or a new RS500 from Kiesler if they ever release it. If I find the right deal on a t56 I would use that.
Yeah, buying parts on here and running LS1/6 parts will definitely be a good budget minded way to do things. People get rid of that stuff dirt cheap. It will still make plenty of power if set up correctly. Good luck with ya'lls builds. If you want any more opinions or advice just let me know.
