New to LSX's would a cam swap be worth it?
Old 01-08-2012, 03:40 PM
01 blue bullitt's Avatar
Default New to LSX's would a cam swap be worth it?
I have a 99 WS6 which currently has the following
Built auto with a 3800 stall
Torquer V2
PRC stage 2.5 5.3 heads
TSP 1 7/8" longtubes and TSP x pipe
Fast 92/92
Stock gears
150 shot
I am wondering if the car would benefit from a larger cam? If so what would you recommend? I want something that sounds more aggressive.
Old 01-08-2012, 06:31 PM
zracer323's Avatar
What are your goals with your car? If it is a street car then a wouldn't bother changing that cam. It's a good proven mid-sized cam. You could go bigger but may sacrifice some driveability.
Old 01-09-2012, 06:49 AM
The car does see some street use but will mainly be ran on motor occasionally spray. I would like to get solid 11's out of the car on motor to bracket race.
Old 01-09-2012, 08:02 AM
Ronny_02_WS6's Avatar
Switch to torquer V3
Old 01-09-2012, 08:08 AM
Captain Double Post
BOBS99SS's Avatar
whats the car run now, it should be in the 11s with those mods
Old 01-09-2012, 08:44 AM
1964_442's Avatar
I have the v3... and there are people in the 11s with the v2 and similar setups, how is the suspension and tires ?
Old 01-09-2012, 08:58 AM
87gnx's Avatar
Toss the stock gears while your at it. $.02
Old 01-09-2012, 10:29 AM
usafws6's Avatar
^^ you need some 3.73s
Old 01-09-2012, 10:40 AM
thunderstruck507's Avatar
I wouldn't bother.
You can only go so much bigger without PTV clearance issues anyway.
Old 01-09-2012, 12:20 PM
I haven't ran the car yet, I am in the process of doing some suspension as we speak just wasn't sure if a cam swap would be worth while.
Old 01-09-2012, 12:39 PM
Tobias05's Avatar
I'd do gears, or save up for a rear end.
Old 01-09-2012, 01:11 PM
udienow's Avatar
You should already be in the 11's with those mods. If you got 2.73 gears I could see that slowin u down more then anything, and of course you will want a DR.
Old 01-09-2012, 08:23 PM
zracer323's Avatar
I would run it with the V2 first and see what it runs. If you still aren't happy, then think about swapping.
Old 01-09-2012, 08:39 PM
NVUSZ28's Avatar
For a Shot of N2O, and you want to up your cam, go with a Texas Speed 233/239.
Old 01-09-2012, 11:44 PM
prokilllsx's Avatar
You should already be mid 11's. You are second-guessing yourself. Put some sticky tires on it and leave hard, if it's not in the 11's put some gear to it and it will be. Your combo seems just about perfect for your goals.
You've never run it? Dude, swapping your cam now would be like dumping a hot chick right before the first date. C'mon, run that thing.
Old 01-10-2012, 12:16 AM
lemons12's Avatar
That should already be mid 11s, almost exactly.
He has a Ws6=3.23s
LOL at people saying cam swap isn't worth it..... But swap to 3.73s from 3.23s... Yea, 400+$ and you gain So0o0o0o0 much from a gear swap.
Run it and see where you stand.
Old 01-10-2012, 05:57 AM
It runs pretty hard on motor, I have yet to spray it. Just new to all this stuff. I talked to Patrick G he said the car WOULD pick up with a custom cam or even maybe a shelf cam, but the power would only be 10-15 hp.
Old 01-10-2012, 07:02 AM
Captain Double Post
BOBS99SS's Avatar
if you deal with pat im sure he could get ya more out of your setup,but honest i would make a few lil changes and run it, you might be happy with what you got
Old 01-10-2012, 04:13 PM
prokilllsx's Avatar
When cost is factored in with performance gain, the correct cam change will get you more for your money, IF you want a faster time. Changing the gears from 3.23 to 3.73 would make the car FEEL quicker while actually netting you very little e.t. for the cost and headache.
The whole conversation is pointless though if you don't know what the car runs now. It would be different if your original post said "Car feels sluggish, please help". Instead, you are basically asking how to get to a time that you are likely already at.
Save money; Run that thing. Or as a hick co-worker used to say "Far on at hot rod!" I think he was trying to say FIRE ON THAT HOT ROD, or Get on it! LOL
