98-00 cam ?s - LS1TECH
98-00 cam ?s
Thread Tools Search this Thread
Old 01-23-2012, 11:12 PM   #1
Default 98-00 cam ?s
If I am wrong someone correct me but the 98-00 cam is slightly bigger than later years? I'm wanting to know if it'd be worth it to swap an 98-00 cam in an 02 car? I'm not wantin to spend a lot of money and what would power gains be if any? All answers are greatly appreciated
DCbojangles is offline   Reply With Quote
Old 01-23-2012, 11:15 PM   #2
ds98formula's Avatar
No gain will be seen doing this.
ds98formula is offline   Reply With Quote
Old 01-24-2012, 01:05 AM   #3
S8ER95Z's Avatar
Might as well go after an ls6 cam... Cheap and you will see some gain. I doubt you would see much of anything from the older ls1 cam.
As most will say though... If you are going to do it make sure you get what you want so you dot regret it later. I spent a little over 200.00 to swap my cam and I'm happy with my results so far.
S8ER95Z is offline   Reply With Quote
Old 01-24-2012, 02:02 AM   #4
02CamZ28's Avatar
Ya you wouldn't see anything. Ls6 wouldn't be bad like state above and they cheap. On the other hand I got a torquer 2 and am very well pleased
02CamZ28 is offline   Reply With Quote
Old 01-24-2012, 03:22 AM   #5
LS1Tech Administrator
RPM WS6's Avatar
The old cam would probably be worth a slight gain in an '01+ engine, but the gain would be so small that it wouldn't justify the cost. As suggested above, if you want to do a cam swap, go with an LS6 cam at the very least.
Here are the stock cam specs:
98-00 LS1:
Duration@.050 198.86 intake 209.25 exhaust
Lift .498 intake .497 exhaust
LSA 119.45
01-02 LS1:
Duration@.050 196.37 intake 208.72 exhaust
Lift .464 intake .479 exhaust
LSA 115.92
RPM WS6 is offline   Reply With Quote
Old 01-24-2012, 06:02 AM   #6
ULTIMATEORANGESS's Avatar
i wouldnt go with a mild cam never mind a stock one. youll be sorry you did and want something better.
ULTIMATEORANGESS is offline   Reply With Quote
Old 01-24-2012, 06:03 AM   #7
justin hover's Avatar
Your sig says bone stock...get other supporting mods first....
justin hover is offline   Reply With Quote
Old 01-24-2012, 07:40 AM   #8
homerz28's Avatar
if you wouldnt see any gain, then why did GM swap them out to begin with?
homerz28 is offline   Reply With Quote
Old 01-24-2012, 07:53 AM   #9
Quote:
Doesn't matter though...you might see a gain on a graph, you'd never feel the difference. It's not worth the time installing it. If your gonna get a cam, then save the money and get a cam. Do it right...don't settle for stupid **** cause your impatient...
Old 01-24-2012, 08:04 AM   #10
homerz28's Avatar
Quote:
justin, you did not in any way answer my question.
Old 01-24-2012, 08:06 AM   #11
Kleeborp the Moderator™
MeentSS02's Avatar
They got rid of EGR in '01 when they swapped to the LS6 intake manifold. The smaller cam helped reduce emissions so they could do this and still be okay with the EPA.
MeentSS02 is offline   Reply With Quote
Old 01-24-2012, 08:26 AM   #12
S8ER95Z's Avatar
Quote:
This.. they bumped ratings but dyno results will show them making about what the previous years made already. You might pick up 5rwhp if you are lucky. I picked up 2mph and 4 tenths with the LS6 Cam swap (untuned and my fuel pump died 3 days after I was at the track for whatever that is worth.) Guessing 20rwhp gain at this point..won't know until I get it on a dyno again.
If you are after nice gains though plenty of cams exist that will give you great drivability and power increases.
Old 01-24-2012, 09:09 AM   #13
TransAmWS.6's Avatar
Quote:
Exactly, I don't understand the point of swapping one stock cam for another. Most cams out there are not very expensive, I would just do a little more research on the various grinds that are available through the aftermarket and buy one that will actually be worthwhile.
TransAmWS.6 is offline   Reply With Quote
Old 01-24-2012, 09:30 AM   #14
homerz28's Avatar
Quote:
I guess for the same reason why some people swap their stock camaro rims for stock corvette rims..
Old 01-24-2012, 09:44 AM   #15
S8ER95Z's Avatar
I will be honest..the only reason I did it was I thought I had a bad lifter.. the engine was making an odd rattle. So I started researching and pricing lifters. I found my cam, springs, lifters and pushrods for 200 shipped. The price of lifters would have been close to that so I went for it. It was only after getting everything that I realized 'derp, heads have to come off'.. so I just did the cam swap and checked the stock cam for signs of wear. I figured if the stock cam had problems I would pull the heads otherwise I would save myself the headache. Entire swap ran me a tick over 200 as I did the work myself and the stock cam looked perfect so I avoided pulling the heads.
Old 01-24-2012, 10:00 AM   #16
Well, that's a little different.
I gotcha, your situation was a bit different though, I'd say. If you're not doing it for repair purposes and you just want some good gains, I don't think going from a stock LS1 cam to another stock LS cam is worth it when you have such a wide selection of good streetable aftermarket cams that are specifically designed to yield decent gains, while still maintaining good driveability.
Old 01-24-2012, 10:07 AM   #17
S8ER95Z's Avatar
If I had a grand at the time I may have considered a bigger cam.. running on stock tune was a plus for me and saved a ton of money in the short run. The end results are not 'great' by any means and if someone has any kind of budget I would certainly recommend a bigger cam.
The only 'plus' I have found to my swap is a slight gain in MPG... I am guessing this has to do with the cam profile and the Z06 having much steeper gearing than I do... but so far I have a bump of 2mpg average and I'm not going to complain about it. lol
Old 01-24-2012, 11:18 AM   #18
MeentSS02's Avatar
There's nothing wrong with the LS6 cam...I had one in my Camaro that I just sold. My stock timing cover had a small crack around where the crankshaft snout seal was, so I had to replace it. I figured if that was off, a cam swap wouldn't be too hard, but I didn't want to mess with a larger cam at that time. Plus, the parts were WAY cheaper to do this, so I figured why not.
I'd do it again if I had the chance, and would probably add some nice 243s or other aftermarket heads for a very nice performing car with absolutely stock driving characteristics.
Old 01-24-2012, 12:33 PM   #19
RPM WS6's Avatar
Not the same.
There is a very noticeable visual difference between Corvette wheels and Camaro wheels, as well as a significant handling difference that you can actually feel between 16" and 17/18" wheels. Not to mention, the only work involved is 20 lug nuts and a floor jack.
The cam swap you are suggesting would net such a small gain that you won't feel it, and the amount of work involved is exponentially higher than doing a wheel swap.
I understand the idea of wanting to use as many stock parts as possibile for most stock-like driveability, and as such the LS6 cam would be a great choice. It's still a stock part, came from a Corvette (just like the wheels you have suggested), and the gains will actually be noticeable. Anything smaller than this cam just won't be worth the time or money to do all that work.
Old 01-24-2012, 12:36 PM   #20
MeentSS02's Avatar
Quote:
And it was barely worth it even for the LS6 cam IMO. I noticed an improvement at first, but I got used to it VERY quickly.
Tags
2002, 98, 9800, cam, camaro, camshaft, gains, ls1, ls6, power, start, swap, trans, wont, x3
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
