ls1=402?
Old 01-27-2012, 11:27 AM
combs_425's Avatar
Default ls1=402?
can i make a ls1 into a 402? i know i can only hone it over .005
Old 01-27-2012, 11:33 AM
Rare96LT1Formula's Avatar
AFAIK, no.
I believe you'll need a 6.0L block to achieve those cubes. Someone please advise if I'm mistaken.
Old 01-27-2012, 11:35 AM
BigBirdLS1's Avatar
I don't think you can IIRC the biggest you can make a 346ci LS1 block is 396ci. I am no expert but I'm almost positive you would have zero cylinder wall left at 402.
Old 01-27-2012, 11:38 AM
smokeshow72's Avatar
If you sleeve the block you should be able to take it out to 454 from what I remember; at least 427.
Without sleeving the block I think 383 is safe but much bigger than that your rod/stroke ratio gets pretty sketchy and you can't overbore the stock cylinders more than .010 from my understanding.
C
Old 01-27-2012, 11:43 AM
3.8redbird's Avatar
3.91 bore with 4.125 stroke is the biggest I have seen making a 396.
Old 01-27-2012, 11:48 AM
combs_425's Avatar
I just didnt know if I could hone it and then stroke it to get me to a 402. IDK why but I have my heart set on a 402 for my next build.
Old 01-27-2012, 11:59 AM
zracer323's Avatar
A 402 will require a 6.0 block (LQ4/9 or LS2) without resleeving the LS1 block.
Old 01-27-2012, 12:09 PM
combs_425's Avatar
so it can be done if u resleeve it?
Old 01-27-2012, 12:14 PM
3.8redbird's Avatar
If you are spending the money to resleeve go 4.125 or bigger bore. 427 FTW
Old 01-27-2012, 12:15 PM
combs_425's Avatar
how much would resleeving cost?
Old 01-27-2012, 12:57 PM
ROCNDAV's Avatar
https://ls1tech.com/forums/1250898-post10.html
LS1 blocks from 1997 and 1998 cannot be bored, but can be honed up to .0040".
The liners were redesigned for 1999+ blocks (including LS6) and can be bored up to .010"
All years of blocks are suitable for re-sleeving for bigger bore projects.
Lunati does make a 4.25 stroke crank.
Old 01-27-2012, 05:22 PM
Blk98Vert's Avatar
Surprised not many people know that you can make one a 440.
Old 01-27-2012, 05:45 PM
82cetuner's Avatar
I would resleeve will cost you about the same as a block probably depending on whre you got it.
and if you resleve you might as well go 427 like the others said
Old 01-27-2012, 07:41 PM
Very good block info in this thread:
https://ls1tech.com/forums/generatio...ved-block.html
C
Old 01-28-2012, 12:18 AM
bww3588's Avatar
Last time I had quotes for re sleeveing and square decking was 200 a hole.
To the op, I would start with a virgin ls2 block to get 402, not have to sleeve it and it's still aluminum.
Most people go max of 3.905 bore on 99 up blocks because that is a shelf piston. A 3.908 piston is more difficult to find.
Old 01-28-2012, 08:59 AM
Just something cool about a matching-numbers 427 or 454 in a car that wasn't offered over 346; you don't have to worry about front dress, or knock sensors, or anything not fitting...
Old 01-28-2012, 09:09 AM
Daniel0026's Avatar
4.002 bore (6.0L block honed) and 4.000 Stroke= 402 ci. Thats exactly what I built.
Old 01-28-2012, 09:11 AM
combs_425's Avatar
well i am going to pick up a 00 WS6 with a blown motor. it already has a turbo kit. i just need to build a motor. i really want a 402 but it is probably cheaper to just go with a 383.
Old 01-28-2012, 09:26 AM
Captain Double Post
BOBS99SS's Avatar
i agree , i called around awhile ago and a resleeve is not cheap, imo buying a block would be a way better option
Old 01-28-2012, 11:19 AM
bww3588's Avatar
^^^do you agree or not? Lol. He is saying a block costs the same as a re sleeve...
Quick Reply: ls1=402?
