Getting ready for cam - LS1TECH
Thread Tools Search this Thread
Old 01-28-2012, 07:51 PM   #1
cchesser1990's Avatar
Default Getting ready for cam
looking to buy a cam with my tax return, thinking about tsp ms3 since ive heard good things about it. Obviously i would need springs and pushrods, but is there anything else i really need to do the swap? oil pump? timing chain? Is all of that stuff optional or more or less necessary? Thanks for any advice in advance.
cchesser1990 is offline   Reply With Quote
Old 01-28-2012, 08:36 PM   #2
A.R. Shale Targa's Avatar
An LS2 chain can be had for like $40 bucks and uses your stock gears.
Most replace the pump depending on mileage and budget. I ported the stock
pump and shimmed the bypass spring for a bit more pressure but mine only
had 15 thousand miles on it.
A.R. Shale Targa is offline   Reply With Quote
Old 01-28-2012, 09:29 PM   #3
My car is at 72k. Would a stock ls6 pump be good to swap in?
Old 01-28-2012, 09:32 PM   #4
S8ER95Z's Avatar
If you have the money I would upgrade the pump.
I did my swap at ~130k but have the ls6 pump already so I just left it alone and replaced the o-ring.
S8ER95Z is offline   Reply With Quote
Old 01-29-2012, 08:05 AM   #5
USMC5811's Avatar
Im not positive about a regular ls6 pump, but i put in the ported and shimmed ls6 from TSP and havent had any issues with oil pressure. It was around 150 buckS. Well worth the money
USMC5811 is offline   Reply With Quote
Old 02-05-2012, 10:30 AM   #6
I8UR4RD's Avatar
why ms3? are you going to be doing an NA build with N20 or do you have future plans. your future goals need to be considered before your current ones. TSP has great cams. personally if i could do it again I would go with the brutespeed blower cam. that is one badass cam. and itll let you grow if you decide to add boost later on down the road. its a 115 591. 608 i do believe. sounds great too.
I8UR4RD is offline   Reply With Quote
Old 02-05-2012, 10:48 AM   #7
Ronny_02_WS6's Avatar
Clutch if Manual
Ronny_02_WS6 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
ls2 cam jholmes LS4 Performance 12 01-15-2016 01:15 PM
Need cam help yes i read the cam thread cec326 LT1-LT4 Modifications 2 07-04-2015 06:14 PM
Turbo Cam? Zero4488 Forced Induction 8 06-02-2010 02:02 PM
Need some info about the cam idle wot_denali Generation IV Internal Engine 5 01-02-2010 10:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
