what headgasket set did you use?
I recently used the Fel-Pro Permatorque and they have done well. A little easier on the budget then GM MLS and designed to be more forgiving for less then optimal surface prep, I say win/win.
GM MLS LS9 head gaskets. It's proven to be the best head gasket you can run. People have ran them from a 5.3 all the way up to big bore motors.
Lots of people have done the rod bolt upgrade. BUT, some have had issues with pre-mature failure of aftermarket rod bolts or bearing failure as a result. So, I say do at your own risk.
