Help!
Help!
I just put 17x9.5 Zr1's on my 99 ta and there is a rubbing noise coming from the front i have checked the wheel and tire there are no rub marks and i also checked the brakes they are good too i know its gotta be something simple (i hope) he car has kuhmo's on the front and nitto's on the back if that helps please someone help
Well, in general if the problem started when you made a change then you should begin to undo that change until you find when the problem stops. To that end you might try (if you still have them) to re-install your stock front wheels/tires and see if the noise persists. In my experience the coincident thing happens from time to time, but most often it has to do with your most recent change.
