SICK CAM for LS Cars
Old 02-21-2012, 09:01 AM
Sales@Tick's Avatar
Default SICK CAM for LS Cars
Due to loads of questions about "what cam should I go with" and the extremely popular "polluter" cam, we have designed a camshaft upgrade package that puts down the horsepower and torque numbers for your LS based machine!!! If you are in the market for a new cam, or if you are looking to put a cam in your LS based ride, this is the perfect cam for you. Check out the link below for more details!
98-02 Fbody
http://www.tickperformance.com/tick-...grade-package/
http://www.youtube.com/watch?v=XfKhP...eature=related
http://www.youtube.com/watch?v=l6HKv...eature=related
http://www.youtube.com/watch?v=vnpDc...eature=related
Old 02-21-2012, 10:28 AM
The Mighty Texan's Avatar
Looks pretty good on the graphs!
Old 02-21-2012, 12:48 PM
Sales@Tick's Avatar
Yes it is a very solid performing cam, we have had guys with more bolt ons that made similar numbers to that of lower performing head/cam cars.
Old 02-21-2012, 03:55 PM
MikeWS6's Avatar
I have been debating this for 3 months now. I just cannot decide between the polluter, street sweeper, or the torquer v2.
Old 02-21-2012, 04:02 PM
Sales@Tick's Avatar
Cant go wrong with the polluter, makes great numbers, sounds awesome, and has good driveability.
Old 02-21-2012, 04:49 PM
MikeWS6's Avatar
Its better on the street vs an ms3 right? My car is not a dd I only drive it a few days a week.
Old 02-21-2012, 08:11 PM
CamaroSS27's Avatar
Good numbers seems like a big cam, wonder what it would do with some heads?
Old 02-21-2012, 09:09 PM
LS1TECH Sponsor
Jonathan@Tick's Avatar
We have seen near 500 rwhp with the Polluter along with a set of 215 TFS heads on LS1's. With all of the bolt ons, thinner head gaskets, milled heads along with flycut pistons making over 500 rhwp would be no problem.
The Polluter works we'll in just about any combination using cathedral port style cylinder heads. We later built a 408 for the first car to ever receive the Polluter camshaft. With the Polluter combined with a set of 225 AFR cylinder heads and a FAST 92 that car produced 550 rwhp.
I would consider the Polluter to be a "max effort" cam for a stock bottom end LS1/6/2. It is on the large side in terms of what fits with a safe amount of PTV clearance.
With a good tune the Polluter can be very driveable, however to get the most from this or any camshaft of this size a lower gear ratio than factory will help (higher numerically) and a 3500+ stall converter is a requirement.
Old 02-23-2012, 12:50 AM
Petersen's Avatar
Ms4 for sure and no need to flycut if your tight on money. Give up a lilttle lower in torque. But the biggest cam isn't always best it's not a dick measuring contest. Just depends on your plans
Old 02-23-2012, 12:54 AM
the_merv's Avatar
Bigger is not always better..you can only flow so much..
Old 02-23-2012, 09:05 AM
Sales@Tick's Avatar
The "Polluter" cam is the largest ls1 cam you can run without having any PTV clearance. So no need to fly cut the pistons with the polluter cam. Your right though, it does depend on the plans for the car, but generally bigger cams yeld bigger numbers.
Old 02-23-2012, 02:35 PM
K11PER's Avatar
Sounds nice
Old 02-23-2012, 02:38 PM
Cosmos's Avatar
So basically the motor wont turn over?
Sorry, had too
Old 02-23-2012, 02:43 PM
Cosmos's Avatar
But a big cam with CORRECT supporting mods will **** pound a smaller cam all day. You must have proper mods to fully see a big cams potential. I wouldn't go over low 230s with stock heads and compression myself. I notice most people who buy the donkey cams just get them because shops market the peak number they make but dont know you need gears, verter, intake, upped compression and so on to let the cam see its potential.
I knew a guy who had a TRex with stock 3.42s. That thing was a turd.
Old 02-23-2012, 04:08 PM
the_merv's Avatar
^^Good point.
Old 02-23-2012, 04:21 PM
Sales@Tick's Avatar
Sorry, had too
Sure it will... that why they make starters!
Old 02-26-2012, 04:29 PM
camaroboy14's Avatar
Any 1/4mile times?? That's what I want to know the most
Old 03-02-2012, 03:07 PM
CoolAid's Avatar
http://www.youtube.com/watch?v=XKrBraNkNvc
(Jump to 1:40 for the fully warmed up lopey magic sound we all love and desire)
3,800# race weight, full accessories, stock suspension, LS2 GTO w/ full exhaust (3/4 LTs), and a Circle D 4,300 stall converter, stock 3.46 gears, non-shop ported LS2 intake/TB, 555R DRs on stock 17x8 wheels.
Similar DA example:
Same mods, PRE-cam, +1,741ft DA
-1.69 60ft
-7.82 @ 87MPH 1/8
-12.28 @ 110MPH 1/4
Same mods, AFTER Polluter cam, +2,044ft DA
-1.63 60ft
-7.52 @ 93MPH 1/8
-11.80 @ 115MPH 1/4
Pre cam was consistent 12.3xs @ 108-110. After cam is consistent 11.8xs @ 114-115. Despite being a monster cam for stock cubes/heads/gears, I lost no 60ft or 1/8th performance. Quite the contrary. I gained an exceptional 6MPH @ the 1/8th mile! And the 1/4 time/trap tells the other side of the story on how this cam just doesn't quit. Even when breathing through a garbage LS2 intake. Obviously the converter is a big supporting element to why the cam performs like it does in my car, but just going off the cam gains alone the Polluter delivers. This cam will truly shine in my car with some AI ported 243s, a FAST 102 and some 3.91s. Can't wait.
Tick Performance has a winning bump stick here.
Old 03-03-2012, 09:24 PM
Wow pretty good times there !! Nice looking GTO too!
Old 03-05-2012, 10:17 AM
stlracing289's Avatar
Would a Yank SS3600 stall work well with this cam?
Quick Reply: SICK CAM for LS Cars
