Accidently may have got water in the oil...Need Help
Old 03-07-2012, 07:49 PM
stevez2885's Avatar
Default Accidently may have got water in the oil...Need Help
Well im in afghanistan and my brother in law was detailing my car for me and my wife forgot to tell him about my breather that replaces the oil cap. He said he thinks it has water in it and i told him to check to see if it looks milky to confirm if it has water. Also, if it does have water do I just change the oil, run it for a little bit then change it again?
Old 03-07-2012, 07:50 PM
ULTIMATEORANGESS's Avatar
yes, drain it. how much got in?
Old 03-07-2012, 08:01 PM
stevez2885's Avatar
well he said henever sprayed the water directly on the breather so im assuming not much if any at all....just curious of what steps i should take if its in there
Old 03-07-2012, 08:04 PM
stevez2885's Avatar
oh and btw it hasnt even been started since he thinks he got water in it...
Old 03-07-2012, 08:27 PM
drain it till everything comes out.
Old 03-07-2012, 08:31 PM
01 CamaroSS SLP's Avatar
I'm with him, don't take a chance and let it drain for a while.
Old 03-07-2012, 08:39 PM
AlamoTA's Avatar
I'd drain it, fill it, run it, and check the oil. Repeat as necessary.
Old 03-07-2012, 08:44 PM
stevez2885's Avatar
will do, thanks guys!
Old 03-08-2012, 09:31 AM
simplysix's Avatar
I would drain it, and once the its pretty much done draining I would add another qt or 2 of oil to it while the drain plug is still out. This will help flush it a little more.
Old 03-08-2012, 11:10 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Drain the sucker out, add more oil, run, redrain, new filter, check. Should be fine.
- Being a detailer among many things. He should be slapped. In in a supportive, brotherly fashion sort of way.
Quick Reply: Accidently may have got water in the oil...Need Help
