Do-it-yourself catback install?
Old 03-19-2012, 02:30 PM
homerz28's Avatar
Default Do-it-yourself catback install?
hey guys i just got in a Pypes catback in for my 2002 ws6 and i do not own a lift. do you think i could jack the car up and remove the old and install the new? would i have to cut the old catback to get it out? thanks.
-Zack
Old 03-19-2012, 02:54 PM
Internet Mechanic
BlackScreaminMachine's Avatar
IF you want to keep the stock cat back, maybe for a future reinstall. You would need to drop the rear down. Not a bigge but can be done in the driveway with help. I always do exaust work on 4 jacks. I try to get as much height as possible.
If you plan on chucking it out, Saws-all is your friend.
Old 03-19-2012, 03:06 PM
homerz28's Avatar
well i planned on keeping it just in case i ever wanted to return it to stock, but i figured i could always re-weld it back together if i had to cut it right?
i don't have four jacks, i have one, and i was just planning on putting the wheels on blocks do you think that would give me enough height? (the car has not been lowered)
Old 03-19-2012, 03:16 PM
dutinsss's Avatar
if you plan on working on you car much at all i'd go ahead and invest in 2 sets of good jack stands(4 total). you'll be glad you did.
you could re-weld it back on but that just add's more to have to do later. soak all your exhaust bolts in PB blaster the day before you work on it and right before hand and just un-bolt it.
Old 03-19-2012, 03:34 PM
homerz28's Avatar
no man i don't plan on doing much work to it oil changes are about as mechanical as i can get lol. i did put in a set of headers on my truck one time...
Old 03-19-2012, 03:47 PM
wav3form's Avatar
Headers are way more complicated than a catback so you should have no problems. I used a recip saw to cut the stock piping out or else I'd have to drop the rear and no way was I going to do that.
Old 03-19-2012, 03:50 PM
TImmy_Jones's Avatar
An oil change is all it would take. Unless you can bench 3500lbs. with your head, you need to buy some jack stands. End of discussion.
As for the catback install...soak the hell out of the stock Y pipe bolts to catback...and cut the overall pipe to pull the old stuff out. You will never want that POS stock muffler back on there.
Old 03-19-2012, 03:51 PM
homerz28's Avatar
well that truck had a lot more ground clearance on my T/A haha. if i have to cut the old catback to get it out, would i need to cut the new cat back to get it in you think?
here's what i ordered. the ONE youtube clip i found sounded really good.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=200724771806
Old 03-19-2012, 04:12 PM
wav3form's Avatar
Uh no you don't have to cut anything to install the new catback. It'll be a clamp together so you don't have a long welded piece to wrestle around with. It's really easy, you'll see as you get started... lay the pieces out first and you'll see how it will go.
The most time consuming part is getting everything aligned and tucked up high. I recommend you get some high quality band clamps as well. They'll be expensive but you don't want to cheap out on clamps. If you're welding then disregard.
Old 03-19-2012, 09:38 PM
Internet Mechanic
Do it yourself requires BASIC TOOLS!!
Old 03-20-2012, 07:52 AM
homerz28's Avatar
Yes sir
Old 03-20-2012, 08:02 AM
Internet Mechanic
Sorry man, just had to say it. Basic wrenches, floor jack, and 4 Jack Stands. Pry Bar, Saws all maybe and a helper. Depending on how rusty things are, soaking bolts in PB blaster ahead of time is good.
Old 03-20-2012, 11:30 AM
dutinsss's Avatar
you shouldn't have a problem with the tools he listed. but for sure get some jack stands. never get under a car with it just supported by a jack. all it takes is that jack to fail for you to be squished.
i never even knew pypes made stuff for our cars. i think i've heard pretty good about them for mustangs though.
Old 03-20-2012, 11:32 AM
wav3form's Avatar
I used rhino ramps when I did mine if you don't want to use jack stands.
Old 03-20-2012, 01:39 PM
Tribal's Avatar
Ramps are the way to go. They make oil changes a breeze.
Old 03-20-2012, 02:10 PM
ZeeSNuttS's Avatar
This^^^^^ (ramps) put my LM1 cat-back on pretty fast with no problems
Old 03-22-2012, 01:24 PM
homerz28's Avatar
what do yall do to remove the clamp connecting the y pipe to the catback? that dude looks uuuugly..
Old 03-22-2012, 03:09 PM
Ballzee's Avatar
well said...
Old 03-22-2012, 07:08 PM
Furious1's Avatar
Hammer and chisel is what I used...a few good whacks and I had it loose.
Quick Reply: Do-it-yourself catback install?
