2000 T/A Headlight Motor Polarity Issue
Old 05-14-2012, 10:35 AM
NEORedLS1's Avatar
Default 2000 T/A Headlight Motor Polarity Issue
Hey all... I just put a brand new headlight motor in the passenger side of my 2000 WS6. Everything is set up, arms behind the correct stops, motor hooked up correctly, and this still happens. Basically when I turn the headlights on, the driver's side comes up and turns on and the passenger side goes down, with the headlamp still on. When I turn the know to the "off" position, both lights turn off but the passenger side comes up. I was told this may be a malfunction in the polarity in the motor, but it could be fixed rather than taking it back to AutoZone to get another one. I really don't feel like taking this thing all the way back out if I can fix it as it sits. Any help is greatly appreciated.
Here is a video of what it's doing:
http://www.facebook.com/#!/photo.php...type=2&theater
-NRL
Old 05-14-2012, 10:58 AM
AmarilloWS6's Avatar
With the headlights off, manually turn the one that's up down and that SHOULD fix it.
Old 05-14-2012, 11:10 AM
NEORedLS1's Avatar
Tried that. Just continues to do the same thing
Old 05-14-2012, 11:37 AM
I've never had or heard of this issue. It might suck but you'll probably just have to return it. If I were you, if you still had your old motor, I would put the brass gears in. I use did this not too long ago and haven't had a problem since, and they'll never go out again!
Old 05-14-2012, 12:42 PM
NEORedLS1's Avatar
Might just have to do that. Brass gears can be found on eBay right?
Old 05-14-2012, 12:45 PM
bwilde86's Avatar
Just switch the wires going to the motor...instead of black to black and green to green...go green to black...problem solved
Old 05-14-2012, 12:52 PM
Yeah man, it's $100 total and you'll never have problems again.
Old 05-14-2012, 12:53 PM
I've never heard of this, guess you've had to do it before?
Old 05-14-2012, 01:05 PM
autogeek23's Avatar
yep on ebay or on ws6 store for $50
Old 05-15-2012, 03:58 PM
NEORedLS1's Avatar
This is what I've been hearing through some other forums. Think I may try that route.
Old 05-15-2012, 04:51 PM
bwilde86's Avatar
I had to do it to mine...just make sure the arms are in the right place
Old 05-16-2012, 11:57 PM
AmDWs6's Avatar
its a game of disconnection of the motors.
Old 05-17-2012, 08:03 AM
88gtman's Avatar
If you are absolutely positive the arm is on the right side of the stops then switch the wires. I have only seen this problem though when the arm was on the wrong side of the stops.
Old 05-23-2012, 01:46 PM
NEORedLS1's Avatar
Switched the wires and then the motor didn't move at all. Reconnected the wires and back to square one. I'm starting to really hate this thing lol
Old 05-23-2012, 04:20 PM
bwilde86's Avatar
It should do something ....
Quick Reply: 2000 T/A Headlight Motor Polarity Issue
