Will a LS1 intake work on a LS2 ?
Old 06-26-2012, 08:05 AM
Houston_t's Avatar
Default Will a LS1 intake work on a LS2 ?
My motor came out of a 2008 TBSS so I'm in the market for a intake. I find more LS1 car intakes than LS2's and at a better price so I'm wondering can I use the LS1 ? I know that it will physically bolt up to the engine, my concern is more so with the difference in throttle body sizes ( TBSS is a 90mm ) would this hurt my performance ? Are the injectors smaller also ? I just figured GM went with the 90mm for a reason.
Old 06-27-2012, 07:05 AM
conan's Avatar
Go with the ls6 intake if you are buying one.
Old 06-27-2012, 07:08 AM
bww3588's Avatar
I answered this in your other thread. The Ls2 intake sucks. Plain and simple. As does the ls1 intake. Go with an ls6 intake and a stock 78mm tb and you won't be leaving anything on the table.
Old 06-27-2012, 09:21 AM
Houston_t's Avatar
Does the ls6 take a 3 or 4 bolt tb ? I was just concerned about using a smaller than stock tb. Thanks for the help
Old 06-27-2012, 09:24 AM
Storm Trooper's Avatar
LS6 intake works fine with stock tb...
Old 06-27-2012, 03:43 PM
2win_SS's Avatar
LS1/6 take 3bolt TBs... Forget about the LS2... Go with LS6. You can find them for $350 average. Just port the stock TB. LS6 flows better than LS2. it's been proven. But you will need fuel rails and injectors for any intake you go with. LS1/6 use same rails and injectors. Goodluck with swap
