short throw shifter
Old 06-27-2012, 01:21 PM
beastlyredz28's Avatar
Unhappy short throw shifter
i have a mgw short throw shifter but i want a shorter shifter rod. anyone have any suggestions on where i can buy a shorter rod?
Old 06-27-2012, 01:40 PM
TyCZ28's Avatar
http://www.ws6project.com/user_stor/...short-stick-1/
There ya go!
Old 06-27-2012, 02:13 PM
777's Avatar
I have the short stick from ws6store. I'm very pleased.
Old 06-27-2012, 03:50 PM
2win_SS's Avatar
I dnt think you can use the ShortStick on the MGW... just cut and re-thread your existing stick. Done
Old 06-28-2012, 09:18 AM
udienow's Avatar
Yeah I dont think that works on the MGW. I did a lot of research on the MGW in the past as I have been looking to get one myself, and I think your only option is to cut the actual stick and re-thread it.
Old 06-28-2012, 09:29 AM
2win_SS's Avatar
^^^ Thats all there is to do. If u want a shifter you can swap sticks. Get a hurst or pro5.0, B&M MGW can't change Sticks
Old 06-29-2012, 08:02 PM
bwilde86's Avatar
How would you rethread it?
Old 06-29-2012, 08:10 PM
My6speedZ's Avatar
Any machine shop could do it.
Old 06-29-2012, 09:05 PM
BackNBlue's Avatar
If you have a newer MGW that's not stepped you can just cut the end off that goes in the shifter. No retreading needed. If you have the old style rod you might just get a new one from them?
Old 06-30-2012, 07:19 PM
2win_SS's Avatar
True cut the bottom of stick. Dnt need to thread
Old 07-02-2012, 08:41 PM
94zGreen's Avatar
I think I have the new style, there is a little notch about an inch and a half from the bottom that has a groove around it, and the instructions say to cut it there if you want it shorter. Hope that helps!
Old 07-03-2012, 09:27 PM
xxKennyDxx's Avatar
I thought the MGW was a little shorter than the stock shift stick?
I just ordered mine last night. I don't mind how the Hurst I have sits now, is there a height difference from the two?
Old 07-03-2012, 09:31 PM
My6speedZ's Avatar
with the Hurst **** no not much might even be a bit shorter. When your using a different **** like a Hurts ball **** that is threaded as deep it will sit kind of high.
Old 07-03-2012, 10:26 PM
xxKennyDxx's Avatar
Ah, what did you end up using as your ****?
I don't mind how it sits stock to be honest. But looking at the WS6Store..man that looks right!
Old 07-03-2012, 10:48 PM
trans damm's Avatar
I notice when ordering mgw shifter there are two options for thread. One is stock and the other is a different thread/pitch. What are you guys ordering. Btw sorry to butt in on your thread but didn't want to start a new one for a simple explanation.
Old 07-03-2012, 11:18 PM
My6speedZ's Avatar
I started with the Cue Ball **** but I didn't like it and gave it to my dad to use. Now I am running the factory H leather ****
I order it with the stock threads.
Old 07-03-2012, 11:36 PM
trans damm's Avatar
That was my plan. Thanks.
Quick Reply: short throw shifter
