Rearend question
Old 06-30-2012, 09:55 AM
redcamaro4140's Avatar
Default Rearend question
Hi my questions is I have a 99 v6 Camaro I put a 99 ls1 rearend in it that rearend had no abs on it. So I'm asking If I keep my abs wire plug in and just zip tie it up and out the way will it hurt anything please I need to know soon I want to take off jake stands Thanks
Old 06-30-2012, 10:58 PM
combs_425's Avatar
no but you will not have abs. you will also get a dtc. Im pretty sure that you can turn it off with hp tuners.
Old 06-30-2012, 11:54 PM
I all ready did the delete check I just wanted to make sure plug in abs wire and just zip tie up how the way if it would hurt anything it's my girl Camaro
Old 07-01-2012, 12:05 AM
caturnbull1's Avatar
you should be fine. i had a wire off on my abs a light came on saying inop but everything else worked fine just no abs till i pluged it back in
Old 07-01-2012, 12:18 AM
Ya I want the abs wire plug in so my tcs light switch lights up
Old 07-01-2012, 12:20 AM
the light on the switch will still work. i had a wire unpluged on my rear axle. but on the dash the inop light will be on as well
Old 07-01-2012, 11:23 AM
I know the dash will say inop but I broke the light in cluster so they won't be on so tell me I'll be okay with the abs wire plug in and zip tie up out the way yes or no
Old 07-01-2012, 05:42 PM
bpittman's Avatar
Having it plugged in or not doesn't really matter, either way it's(abs) not going to work. Zip tie the connector out of the way and call it a day if you don't care about abs working.
Old 07-01-2012, 06:06 PM
Sweet that's what I did because I don't care if the abs works or not
Old 07-01-2012, 07:09 PM
yes your good to go
