what should i do first a ms3 cam or fast 102mm intake
Old 07-25-2012, 06:37 PM
lq96.0's Avatar
Default what should i do first a ms3 cam or fast 102mm intake
what should i do first? which one will make more hp? which would be more expensive? and what else would i have to upgrade when putting in these new parts? 01 z28 lq9 6.0 ls6 intake longtube headers. automatic
Old 07-25-2012, 07:00 PM
98camarosixo's Avatar
I have lq9 and had ls6 intake. I wuld definitely out can first no doubt
Old 07-25-2012, 07:07 PM
baalic's Avatar
I would go cam first..... The 102 may be too much without the cam.. And the cam should garner better hp per $
Old 07-25-2012, 07:08 PM
Sorry I ment I would definitely. Do the cam. Swap
Old 07-25-2012, 07:16 PM
baalic's Avatar
to be honest, i would do a stall before cam since your auto, ms3 without it is gona suck a little...
On that note.... Post 1000!!!!!!!!!!
jarheadtex's Avatar
CAM...all day
Old 07-25-2012, 07:33 PM
lq96.0's Avatar
What else would I have to get if I get the ms3 cam
Old 07-25-2012, 07:40 PM
AsEpSiS's Avatar
what?
Old 07-25-2012, 07:46 PM
baalic's Avatar
Valve springs, lifters, tune... Where to start.
Old 07-25-2012, 08:45 PM
lq96.0's Avatar
What if I get a cam that is not as powerfull like the
Texas Speed 228R 228/228 .588"/.588" would I still have to get a lot of other parts the car is my daily driverdumdumdumdumdum
Old 07-25-2012, 09:04 PM
bernarlitt's Avatar
No matter which cam you choose you'll still basically need the same parts. ex: Valve springs, retainers, locks, push rods etc......
Old 07-25-2012, 09:10 PM
I8UR4RD's Avatar
the 228r is a badass cam. id take it over the ms3 anyday. it will surprise you. either way, as mentioned you have to strengthen up the valvetrain or you could do some damage. calls texas speed and just get the kit with the .650 springs or .700's and it should run close to $700 for it all including pushrods too. you can do the install yourself, and id strongly advise that you swap to an ls2 timing chain while in there. youll make around 400-410 rwhp im guessing. run low 7's with a good 1.6 60 foot and a stall (the stall will make it alot faster) , but yet again, without a stall its going to try to push you through red lights and stop signs. it gets aggrivating to have to stand on the brakes all the time. you can give PTC a call, or buy my damn near new 3200 10'' inch race converter from them that I had with my 228r. it was $500 new, I'll take $400. so all in all, if you install it all yourself, your looking at about 1100-1200 dollars plus a tune. if someones installing it for you id expect anywhere from 1650-$2100 installed and tuned. depends on how big a crook you find to do the work.
Old 07-26-2012, 12:35 AM
usmcpi's Avatar
You can't run the MS3 with the stock stall. But id start with stall and gears first. Then go cam. Then heads. Then intake.
Old 07-26-2012, 01:36 AM
Bugsy's Avatar
Do a stall before anything else. You'll be glad you did!
Old 07-26-2012, 02:12 AM
bww3588's Avatar
I agree. Stall and gears first. You'll have to get your tune tweakdd a little for shift points and such. However, wait to do the intake the same time you do the cam. You will save money in the long run by not having to pay for a tune twice.
Old 07-26-2012, 06:09 AM
Captain Double Post
BOBS99SS's Avatar
Long story short, big cams are not a budget way of going fast, max effort cams require max effort parts,fast intake/at least 4.10 gears/1 7/8th headers/a good dual exhaust/chris1313 etc, ms3 is a good cam but i would do more research 90% of people that go with a big cam wish they would have gotten something smaller, imo i would go with something in the low 230range, if your after the sound you can get a big cam sound on a much smaller profile
Old 07-26-2012, 06:10 AM
Captain Double Post
BOBS99SS's Avatar
With that said, i would do a stall first,run a ls6 intake for awhile untill you can get some of the main parts, then when you have it running good go for the fast
Old 07-26-2012, 02:39 PM
lq96.0's Avatar
What stall and gears should I get. I'm new to all this stuff.
Old 07-26-2012, 02:55 PM
NC98Z's Avatar
Now you have to descide if your gonna spray or not. If you are then something onn the order of a SS3600-4000 Yank. If your not then a PT4000 like I'm running. If you are gonna run 26" tires get the 3.73 gears. If your running a 28 " tire then a 4.11. Yukon make the quietest gears I've ever had installed.
Old 07-26-2012, 03:04 PM
clonedws6's Avatar
Had tons of people and even this same guy telling me all this bull before I bought my cam as well. Blah Blah Blah big cams suck yatta yatta. I love mine and the way it made my car run. Low 12s in a gto with cam and bolt ons, winning.
Im pretty sure 98% of this dudes posts are hating on big cams. They all say the same stuff too lol
Quick Reply: what should i do first a ms3 cam or fast 102mm intake
