Vette motor as warranty replacement??
Old 04-10-2004, 12:58 PM
Supremacy's Avatar
Talking Vette motor as warranty replacement??
So my brother owns a 02 ws6 he got with 19k miles.Around 24 k he started experiencing the piston slap and took it in for a warranty replacement.After about a month,in wich time they gave him a temp motor while the crate came in from gm,he walked in friday and saw 4 techs huddled around his car,all on the phone with other techs.He saw the reciept and was told by the manager that he was getting a 04 production vette ls1.If im correct,the vette ls1 has 380 hp??is there anything in the switch that would decrease the hp??anyone else get this as a replacement?
Old 04-10-2004, 01:08 PM
1BADFNZ's Avatar
nope vette's still got 350 hp, Z06 (ls6) have 405 hp as rated from factory
Old 04-10-2004, 01:14 PM
Supremacy's Avatar
thats right i forgot,since ive heard that gm underrated these motors anyway,isnt a fbody stock ls1 (flywheel)hp around the same?
Old 04-10-2004, 01:18 PM
ActionJack's Avatar
Hell, I am taking mine in. I have been having piston slap and would love for a chance at a higher HP.
Old 04-10-2004, 01:36 PM
1BADFNZ's Avatar
yup a f body ls1 will dyno the same as a c5 ls1. GM just gave it a lower number to appease sensitive corvette drivers LOL
Old 04-10-2004, 01:52 PM
BadAndy's Avatar
Actually the Fbodies usually dyno higher than the C5s, due to the drivetrain.
Old 04-10-2004, 02:17 PM
slow's Avatar
its the same as the stock 2002 LS1 motor, but should be a LS6 block for sure.
no power gains.
Ryan
Old 04-10-2004, 02:47 PM
Zo6Killer's Avatar
I would imagine it's still good for cruise-in conversation starting.
Old 04-10-2004, 06:10 PM
ChiefBrody's Avatar
A Corvette LS1 wont work in a fbody. The oil pan is different and so is the accessory setup. Also the throttle body is drive by wire on a vette.
Old 04-10-2004, 06:52 PM
slow's Avatar
im fairly sure they are going to use the f-body parts but a vette longblock.
Ryan
Old 04-11-2004, 10:25 AM
Supremacy's Avatar
their using whatever they can from the original motor,but have to change alot more.they seem to be challenged by this job,prob never even had to do a swap like this at their dealership..
Old 04-11-2004, 10:38 AM
ULTIMATEORANGESS's Avatar
from what i understand you get whatever your car came with.the dealer will put in the part # and GM will send a replacement part.
of course if changes or upgrades are made from a part being defective youd get that part.
Old 04-12-2004, 11:10 AM
ChitownLS1's Avatar
I had the same thing done late last year. They replaced the block with a brand new LS6 block after 2 months of sitting at the dealer.
Old 04-12-2004, 12:24 PM
FenixSS's Avatar
Damn, how does someone get in on that?
Old 04-12-2004, 12:47 PM
z98
z98's Avatar
FenixSS: HES NOT GETTING ANYTHING SPECIAL
ULTIMATEORANGESS: "from what i understand you get whatever your car came with.the dealer will put in the part # and GM will send a replacement part."
I bet a wooden nickel its the same part #
Old 04-12-2004, 01:14 PM
XuhQshinR's Avatar
The part numbers have changed and if the car is still under original warranty he will get the replacement part (NEW). As long as the vehicle is under original warranty they will not replace with a remanufacured one. It will be New.
The GM Production LS6 block has the corvette oil pan installed on it but also ships with the oil pan for the F-Body and will have to be installed in place of the vette pan. He may or may not get the LS6 heads. That is depends on what they ship. It is my understanding that they no longer produce the exact same LS1 block for todays production vehicles as the ones we have in our original cars. Todays LS1's now ship with an LS6 block.
This is what I was told from a GM tech when they had mine in for severe piston slap. They replaced the rings and pistons and had them fitted with the new coated ones for the 04 Vette, but guess what.....The slap is coming back!
Old 04-12-2004, 01:28 PM
jrivera04's Avatar
I just had my block replaced with a complete LS6 from piston slap as well. I even got the old LS1 block sitting in my garage because there was no core charge on the LS6 and my extended warranty company didn't want the LS1. I think I'm going to turn it into a 383.
Attached Thumbnails Vette motor as warranty replacement??-ls1-side.jpg   Vette motor as warranty replacement??-ls1-top.jpg
Old 04-12-2004, 04:42 PM
FenixSS's Avatar
Oh, this is only if still under original warranty? What does piston slap sound like? (newbie). I've got about 27 days or 163 miles remaining on factory warranty.
Old 04-12-2004, 04:55 PM
AK's WS6's Avatar
Well tell him he is a VERY lucky man!!! If they ever change their mind and will fix my car I will not accept the piston's only swap that some have gotten, that is just a cheap band-aid fix and most hear the slap come back after a couple hundred miles, the stock pistons are fine....it's the block (bores) that are junk!!
Old 04-12-2004, 10:22 PM
Joker's Avatar
What if you have mods like an air lid, no screen in the MAF, etc... would the warranty guards try and void the warranty???
