Guages
Guages
I have a 98 camaro ss. My temp amd oil press guages don't move at. Have any of you guys ever had this problem. Also when I have the parking brake on it doesn't show the brake light. My gas neddle doesn't go all the way down when I turn off the car but works fine when car is turned on. Do I need a new guage cluster.
LS1Tech Co-Founder
Could be your gauge cluster, or the sensors. The engine temp sensor is on the driver's side cylinder head, just in front of the first exhaust exit (near front of engine, brass looking screw-in sensor). The oil pressure sending unit is located behind the intake manifold, near the firewall (black cylinder looking screw-in sensor, not visible with the intake on the car).
Hopefully your car doesn't have electrical problems, did you buy it used and they didn't work?
