LS1 intake bolt question
Old 04-26-2013, 01:46 PM
pappy83's Avatar
Default LS1 intake bolt question
doing the ls6 intake and pcv conversion and when i took our intake bolts out they had some black carbon on the threads and the passenger side front was a little worse then the rest. do I use sealer on the bolts when i put them back in, they had no oil up high on them just at the thread area.
Old 04-29-2013, 11:02 PM
kvrL33's Avatar
I am no expert but I just reinstalled my intake a couple weeks ago. I did not put anything on the bolts. Make sure to use the correct torquing sequence and you should be fine. Final torque is 89 inch pounds. Like I said, I am no expert. Maybe try posting something in another section on this forum and you will get more info.
Old 04-30-2013, 07:59 AM
conan's Avatar
I have always installed them dry. Clean your bolts and blow out the threaded holes in the heads and torque to spec.
Old 05-01-2013, 10:42 AM
2000PewterT/A's Avatar
Same here, just make sure the hole and threads are clean and you should be good to go.
Quick Reply: LS1 intake bolt question
