Too much oil?
Old 04-24-2004, 04:09 PM
Brandon Boomhauer's Avatar
Default Too much oil?
Took oil and filter to the quick change place the otherday since I don't have ramps and it was pretty crappy weather out. Anyways I took 6qts and they used it all, I knew the guys up there and he checked it and said it needed the full 6, is it too much? On the dipstick its above the fill line, should I drain some?
What would a extra 1/2 hurt? Thanks
Old 04-24-2004, 04:18 PM
Dueledaily's Avatar
My 98 usally takes around 6. It depends on what capasity oil filter you put on.
Old 04-24-2004, 05:38 PM
LS1TECH Sponsor
Steve Burger's Avatar
I run the long filter and 6 quarts all the time.
Old 04-24-2004, 05:39 PM
tuffluck's Avatar
i think these engines can safely take up to a quart extra. i wouldn't bother with it. i run 6 quarts and a bigger filter, and mine is slightly above the dipstick reading it *should* be at. not a big deal
Old 04-24-2004, 07:06 PM
ULTIMATEORANGESS's Avatar
youre fine.
Old 04-24-2004, 08:34 PM
Thanks, I used the M1-107 filter FYI.
BTW I also used the German Castrol 0w30. It looked like antifreeze... weird...
Old 04-24-2004, 11:34 PM
Z06PSI's Avatar
Owners manual states 5.75 qts I do believe.... your fine...
Old 04-25-2004, 01:34 AM
Thanks, just sounds like it has more piston slapage or lifter noise around 1500...
after its good and warm its gone........
Old 04-25-2004, 04:49 AM
Patman's Avatar
Hehe, the green color throws people off but trust me, it's good ****!
Old 04-25-2004, 10:02 PM
Patman,
I had looked for it at the Azone before, but I just looked in the front and the back. The front was yellow label, and the back was red but USA.
I know the guy working there and he said they would have more in the morning, I'm going back to see, then stock up.
While I'm on the subject is the M1-107 worth the silver? Or should I go for the K&N?
I should be ok for 100+ temps this summer with the 0w30 right?
Old 04-25-2004, 10:05 PM
tuffluck's Avatar
go for the k&n. if not, then get something like an stp filter. i guarantee you that m1 filters are totally not worth the money, even though the same company makes all three
Old 04-25-2004, 10:48 PM
Ferocity02's Avatar
I put in 6 quarts every time with normal filter. People put in up to 7 quarts for road racing applications, I would not reccomend doing this however.
Old 04-26-2004, 12:25 AM
tuff elaborate please?
Old 04-26-2004, 01:10 AM
14u2nv's Avatar
Where did you get the GERMAN 0w30 Castrol at?
Old 04-26-2004, 05:14 AM
Patman's Avatar
Patman,
Yes, the 0w30 Castrol works great in hot weather since it's almost a 0w40.
I wouldn't recommend the M1 oil filter, especially not the smaller stock sized one, as it's going to restrict your oil flow a lot more than something like the K&N or STP or Supertech. Go for the longer filters as they flow even more than the stock sizes.
Old 04-26-2004, 03:57 PM
Will the length affect ground clearance? I dont want to knock it off. I have to drive over lots of huge speedbumps and large dips in the road around here.
14u2nv, you can find it at Autozone, just pull nearly every quart out of the bin and im sure you will find it. I'd stock up on it at the time too, seems to be a nice choice of oil, as Patman says and several people on bobistheoilguy forums...
Old 04-27-2004, 05:08 AM
Patman's Avatar
I used nothing but the long oil filters when I had my LS1 Formula and it was lowered with Eibachs too, and the filter never got hit. The oil pan shields 95% of the filter anyhow.
Old 04-27-2004, 12:22 PM
Thanks, know the stp filter off hand?
Old 04-27-2004, 01:16 PM
Patman's Avatar
It's the S3675
