First header install. questions on egr, air, gaskets
Super newb questions here but i just wanna make sure im doing this the absolute best way possible! im about to have my first set of headers installed and got to looking around at some different things. i was already planning on getting new header gaskets for the install but what is your alls opinions about the egr gasket and air gaskets? (i already have my o2 extensions). are they something i need to do? is it worth the 20$? ive already done some searchs and found some good info but i just want some directed specifically at me. thanks guys and details are appreciated! im learning! slowly but surely hahaha
use the stock GM exhaust manifold gaskets.what are the emissions laws in your state ?can you delete stuff.if so remove the junk and consider a mail order tune from Frost.consider a cut out for going to the track.
Poly motor mounts aren't that much. Considering they will be sitting there, looking pretty as ****, you will kick yourself if you don't do them now. I know the urge is strong, I have a set of long tubes in the garage calling my name now. But I don't have motor mounts yet either, next payday.
+1. These guys are correct. I didn't do motor mounts at the same time and I am definitely regretting it now and I had my motor mounts at the time of my install. I can't find a shop or anyone that will do it for less than $400.
if you do the motor mounts poly, don't get a poly trans mount. it will shake a lot and eat up the mount. I didn't do motor mounts when I did my headers and I don't regret it. also lining up the poly motor mounts is a huge PITA. I went with bbk headers with a ORY and it sounds great. cat and muffler/ egr and air delete. I only use a resonator and had it tuned out. and IMO, don't ever do a mail order tune. its one of the dumbest/wasted money spent. spend the money and put the car on a dyno and do a tune for your specific car. not every car takes the mail order tune the exact same way. some company did that tune on a similar car, at different temps and pressures, with other variables. IMO NEVER do a MOT!
yes get the gm gaskets... i had to use the one's supplied with my hooker headers. But ima eliminate my air and egr with block off plates before i get a tune this month. Get the gm header gaskets from the ws6 store. i bought almost everything from them.
im in the process of the same header install,egr/air removal on a 98 trans am . its my first time and were doin it in my driveway lol! the forums have anwserd most of my questions. i picked up some hooker headers cheap hows the fit on them ? any pointers would be appreciated .
