Crate engine completeness
Hi there, i'm new to LS1Tech forum and also just learning V8 American heritage . I'm currently running tuned 2JZ-GTE (from Supra) FI engine at 20psi with 500hp and 700nm of torque, but after several strikes from it this year i decided to switch to an NA power. And the only option i see is LS series engines, which are modern and reliable.
I'm about to order a crate engine from Summit or JEGS (actually Jegs's price is better) LS3 376/525 but cannot undertsand what exaclty do i need to order to run the engine, apart from the engine itself.
Here is the link - http://www.summitracing.com/parts/na...9233/overview/
JEGS http://www.jegs.com/i/Chevrolet-Perf...1360K/10002/-1 (comes with ECU kit and an oil pan)
So i assume i also need to add:
- alternator
- starter
- engine harness and ECU kit (LS 376/525 HP Engine Controller Kits 19259261)
- power steering pump?
- accessories and belts?
what else?
I will get clutch kit and T56 later, i will order it separately.
Thank you in advance.
- alternator
- starter
what else?
you really want to go to this section of the forum:
https://ls1tech.com/forums/conversions-hybrids-28/
a thread there would get a lot of useful responses
"LSx engine swap guides"
https://ls1tech.com/forums/conversio...ap-guides.html
thank you, will definitely check this section.
started a new thread. https://ls1tech.com/forums/conversio...l#post17537923
i hope i will find an answer here or there =)
These engines cost more but they're also complete turn key packages, make more power, and are built with forged rotating assemblies.
Texas-speed LS3 turn key engine packages.
