May be buying a Trans Am
Hello everyone, hopefully I'm posting in the right section of the forum. I need some advice on something. Today I went and checked out an '01 Trans Am. Only had 62k on it, and it was in almost immaculate condition. Black A4 with code GU5 and G80 so it has a 3:23 posi. Couple mods, Flowmaster catback, hawk pads with slotted and drilled rotors but.. original calipers..could that be a problem? The rotors looked scorn.
There was a grinding noise from the rear of the car. It did not sound like a diff issue but I can't be sure. It sounded like brakes grinding. The brake pedal was a bit stiff. I'm a bit concerned bc I know the 10 bolt rears aren't known for being strong but if this is only a brake problem I would gladly buy the car. I got on it a little and took it up to about 50. The noise is consistent. There was not a single vibration and the pitch of the noise did not change with speed, although it quieted down slightly when braking.
My question is, could the rear end be on its way out soon? Or is this a brake problem? Possible E brake out of adjustment? Thanks!
Sounds like a brake problem, IEhard pedal, noise quiets when pedal pressed, rotors scorned). I will have them replace said items or drop price to account for having to fix said issues. Its an A4, so the rear should hold up just fine.
He is $8000 but negotiable on the price. I was told that the noise is not the brakes, it is just the rear becuase u sit right over it in those cars. I don't buy that. He said he replaced the axle bearings and changed the diff oil to synthetic. That's why I'm unsure about it. Plus the fact that I drove 70 miles 1 way to look at it. Would of been in my driveway now if it didn't have that noise.
I don't want to buy it, replace all the brakes just to find out I may need to spend alot more for a new rear.. But being an A4 and 60k miles, I doubt it could be the rear but I just don't know.
LS1Tech Administrator
Received 1,471 Likes
Why did it need axle bearings at 60k miles? Did he explain what symptoms or reasoning caused him to do this repair? My '02 has the original axle bearings at 105k miles, and it makes no grinding noise at all.
Not true, unless you're driving the car from the rear seat.
That excuse is crap. There should be no constant grinding unless something is amiss.
Exactly. And even then, I used to have an '01 V6 that had 85k when I sold it. Same 10 bolt but the 7.5". Not a single peep out of that rear. It sucks but I'm probably going to pass on this one.
GM stopped gracing the F-bodies with the much stronger 8.5" 10-bolt after the 2nd gen years.
Oh I know that it was the same rear just a couple differences. But really a 7.5"? I thought the V8's had the 8.5". Heck even the weak 4.6 2v mustangs came with the 8.8" Ford rear. I'm pretty shocked they only put the 7.5 behind the LS1.
As much as people knock this rear, it actually is adequate for the vast majority of street driven A4 cars. If you wanted an M6, it would be a different story though.
Yes, they all have the 7.5" whether it's a V6 or V8. No 8.5" since the 2nd gens. There was an Austrailian 9-bolt used for a while in the '80s, but otherwise it's been the 7.5" ever since.
Maybe it could just be brakes. I mean other than that, the car was perfect which is why I'm stll considering it. The KBB is 10.5k although I think KBB is way off. What is the most you'd pay for the car given what I've said? 6.5-7k?
And I have read that the rear gets more shock with the 6 speed, so this car being an A4 it should be fine. I can tell when cars were beaten and this one wasn't.
