is there anything else?
Hey guys I'm looking for some input. So I'm doing a can swap and I think I have everything but want some other opinions. Its a 2000 ss I have a tsp228r can, tsp 7.400 hardened pushrods, PAC .650springs, ls6 ported oil pump, ls2 timing chain, ls6 intake manifold, comp cams reunion rocker bearing kit, timing chain cover gasket, 2 water pump gaskets, valve cover gaskets, front motor gasket, is there any other parts I need please any info will help and is appreciated.
If he is dropping the motor out there is no need to take the radiator out of the car. You will however loose a lot of coolant when you pull the hoses, and take the heads off, if you are going to do that.
