just picked up an 6.0L, thoughts
Old 09-19-2013, 12:48 PM
ToxicWS6's Avatar
Default just picked up an 6.0L, thoughts
just picked up a 6.0l out of a 2000 silverado, im assuming its an lq4 as it has iron heads on it, also heard these cranks are differnt and only fit 4L80Es and older transmissions, not T56
how much if thats true and is there anything else i should know about it? are the heads equal to 317s?
i only paid $350 for intake to oil pan, tb included and all sensors so not to worried but
Old 09-20-2013, 06:24 PM
s14kouki's Avatar
Nice pick dude. Im not very familiar with this builds so i cant help you =/ I went with the simplest swap a ls1.
Old 09-21-2013, 12:06 AM
bww3588's Avatar
It probably has the long crank, meaning it will work with a t56, but only an lt1 t56. And you would have to bastardize a clutch setup probably. Unless you plan on running a 4l80e, I'd sell it and pick up a short crank engine.
Old 09-21-2013, 06:26 AM
ToxicWS6's Avatar
would a 700r4 or older transmission work?
Old 09-21-2013, 08:52 AM
bww3588's Avatar
Any trans that was originally behind a small block will work with the correct flex plate.
Old 09-23-2013, 01:49 PM
ToxicWS6's Avatar
ok thanks! and would this be a smc 350 flex plate or a "custom" swap one?
coild i use the one thats currently in my sb 350/700r4 set up?
Quick Reply: just picked up an 6.0L, thoughts
