2008 0 oil pressure
Yes, it's like the pump isn't picking up at all. Someone told me on some motors there is a small plug in the rear of the motor. I'm not sure if this one has that. I have ran it with the valve cover off and not a drop of oil coming through the push rod/rocker.
Make sure you oil pump o ring is seated properly. Did you replace the oil restrictor barbell. Either way, if your not checking oil pressure with a mechanical gauge, thats the first thing I would do to make sure its not a sensor problem.
