oil catch can 99 t/a
Old 12-22-2013, 07:44 PM
ironmikektm525's Avatar
Default oil catch can 99 t/a
Ordered catch can from covettemods( got decent reviews ) to help with blow by. Read up on how to install. Have seen some putting a breather filter on the driver side valve cover(rear) Should I do this or leave it as is? Any tips/opinions would be great! Thx
Old 12-22-2013, 08:05 PM
99Bluz28's Avatar
Leave the PCV tube in the driver side valve cover alone.
Tip: If you mount the CC away from direct exhaust/engine heat(in a cooler location) the CC will trap more water, oil, and harmful combustion chamber byproducts .
Old 12-22-2013, 08:09 PM
Ok ty! Can I buy a new one of those? If so what's it called? Parts store listed only one?
Old 12-22-2013, 08:18 PM
99Bluz28's Avatar
Why, did you remove the PCV tubes ?
Old 12-22-2013, 08:38 PM
I didn't remove them. I just wanted to replace the pcv. I noticed the valve in the driver side rear valve cover. I pulled it out and it looked little dirty. I could probably clean it up but rather just buy a new one if I knew what it was called?
Old 12-22-2013, 08:51 PM
99Bluz28's Avatar
The only thing that ever need replacing is the PCV valve itself and the rubber Y (behind the rear of intake manifold) usually falls apart causing a vacuum/oil leak. The rest of the PCVystem can be cleaned up and re-used; unless you want to spend around $117+ for a whole new PCV system. To replace the rubber Y, you'll need either a metal or plastic T or Y barbed fitting, or you can replace it with a short section of 3/8" oil/fuel line hose and then cap the rear port on the passenger side valve cover.
FYI, you can't just buy pieces of the PCV system, you have to buy the whole complete system.
Old 12-22-2013, 08:56 PM
Sounds good. Thx alot for the info!!
Old 12-23-2013, 06:51 AM
dhctss's Avatar
Not to get off topic but when i swaped ls1 to ls6 intake i was shocked on how much oil in ls1 intake. I installed the catch can a week after. Defently better gas mileage keeping intake clean of oil just food for thought.
Old 12-23-2013, 07:57 AM
I agree. I swapped intakes couple weeks ago and found same thing. Not a ton but enough to see. Haven't been able to drive it after the intake due to snow. Noticeable difference when you swapped them?
Old 12-23-2013, 10:45 AM
BrntWS6's Avatar
What are your mods? Some cars need the breather tube from the TB removed if your getting oil through it. But don't just use any filter on the oil cap....get the filter RX performance sells. Its a flow controlling check valve.
Old 12-23-2013, 10:51 AM
Full boltons
Quick Reply: oil catch can 99 t/a
