Tach not working
Tach not working
Just bought a 98 TA auto and the tach doesn't work. I got another set of dials from another TA but they were from a different year and not suitable but I had the tach "motor" from them installed in the back of my dials and still it did not work. When you turn the car on the needle jumps from rest up to zero so there is power going to it OK. Any ideas? Is there a signal generator for the tach and where is it? Any help appreciated. BTW, does anyone know what the spare set of dials I got are for? The part # is 16232952JZA
Originally Posted by felton316
The tach is driven by the PCM in these cars. You might want to check for a brocken tach wire that goes from the PCM to the tach.
Originally Posted by rustylt1
Anyone know how to access the tach wire between ECM and tach? The wiring loom runs right behind the engine along the bulkhead and looks almost impossible to remove for inspection. Hope you don't have to take out the engine to get at it! LOL
Originally Posted by technical
I think it's a white wire that runs from the PCM. There should be a white wire on the cluster harness as well.
The problem seems to lie between the ECM and the sensor which monitors engine speed as everything between the ECM and the instrument gages is OK. Is it possible that the fault is within the ECM or maybe the sensor. Is the sensor which monitors engine speed the Crankshaft Position Sensor? If so, I am led to believe that if the CPS isn't working then the engine won't fire. Someone must know!! I need to get my tach working.
