5.3 with ls intake few questions
bought an 02 5.3 installing a 2000 ls1 intake injectors, rail and tb... it did not come with a map sensor the 5.3 looks different but might be able to make fit. should i try or just get an ls1 map sensor? do the other two ports on back of manifold by the map get used for anything or do i plug them?
also the ls1 tb has no sensors looks like my 5.3 tps and air idle control should fit. i cut the coolant lines off the tb, and i will plug the other port for the evap.
