replacing knock sensors on a 2001 trans am
Old 01-22-2014, 11:45 PM
billyflantos's Avatar
Default replacing knock sensors on a 2001 trans am
any problems with clearance of the intake manifold coming off or anything else I should keep a eye out for? thanks billy
Old 01-23-2014, 12:38 AM
OhTwo's Avatar
Watch the oil pressure sending unit at the back of the engine. It will break easily if you hit it as you reinstall the intake manifold. It's not easy to see since it's hidden under the cowl.
Old 01-23-2014, 10:50 AM
NW-99SS's Avatar
Also be careful when re-installing the intake to not pinch the wiring harness. If you do, it will pull timing like it is sensing knock and throw a knock sensor code. Replacing the sensors won't help and you will have to change the harness. Ask me how I know
Quick Reply: replacing knock sensors on a 2001 trans am
