Slipped from 3rd to 2nd
ok today i was driving on my way home from a friends house. i was in third and just gave it WOT as the car reached 5K rpm. instead of going from 3rd to 4th i went from 3rd to 2nd. the car lurched foward and it turned off. as i rolled i turned it back on and was worried that maybe i bent a pushrod. i stop i don't hear the normal tick thats heard when people bend a rod. car rides as powerful as ever. do you think i caused any damage at all even though i can't hear anythin wrong.
i need info somebody help me cause some people say that i for sure have bent pushrods but after i left my friends house i took my car off the line and it scared the sh*t out of me cause it got more sideways than usual and pulled past 5k rpm. what will happen if i go got one bent. will my engine just go???
1 Post
I've misshifted more than anyone else that I know.. If you're not hearing any ticking or tapping then you may have gotten by on this one.. Me on the other hand bent about 3 pushrods..
If you're worried and just want to put your mind at ease.. Pull the valve covers, pull the rods, and roll them on glass to check them out.
Also, from what I was told. If you'd bent a valve you'd definitely know it because the car would probably idle and run like crap. Did you get an SES light at all?
But like you said, you don't hear any ticking, and the car is still running strong. Just be careful and try not to do it again. If you haven't already purchased one, get you a new shifter B&M or Pro 5.0. They help to cut down on the misshifts..
oh thanks alot guys i feel much better now. just the car ran a monster after is happened. so i guess nothing happened after all. no ticking noise and full power through out the power band. i'll make sure to never do that sh*t again thats for sure.
Question: I am not sure, but i think when shifting from 3 to 2, the rev limiter will not be effective, the only thing that would save you is to stand on the clutch ASAP before damage is done. Is this correct?
you can survive a 3-2 mis shift if you get back into the clutch right away...
what gets you is mechanical overrev...
you can shift and miss not get it into gear ...and you will just hit the rev limiter...but its a fuel/spark shut off...
if youshift from 5k in 3rd down into 2nd...you would be spinning like 7500-8000.... its mechanincal ...not fuel/spark related...its completey based on your gears
If you get back into the clutch before it grabs you can keep it from really getting up into the danger zone.... and If you have stock top end you will likely bend a pushrod before a valve...which are cheap and easy to replace...
if you have hardened pushrods...something else has got to go...and usualy at that much rpm it causes valve float...which means piston to valve issue..and you bend a pushrod...... onsome ocassions I have seen the rod bolts let go and you lose the whole motor..
feel lucky...and get a good shifter like a pro 5.0 and learn some proper shifting technique to help eliminate that mis-shift......and when HE gets done with it...buy a 3-2 shift eliminator from harlan(y2khawk)
I have yet to mis-shift, or do a 3-2 shift, or anything of that sort. But, seeing that Harlan is making a 3-2 shift eliminator, made me think, wouldn't a 2-1 eliminator be a pretty good idea too? Seems that would be one that could get messed up quite often as well, if not more often than the 3-2? Oh well, just my .02
-Jason
-Jason
well i got a big scare when i did that but glad nothing happened. for sure when harlan makes that 3-2 eliminator i am getting on of those with the quickness.
Just have to say that just because there are no clear indications of the bent pushrod doesn't mean that it didn't happen. It'd probably still be worth the time and effort just to check. You might've done something small that would result in a 5 HP loss, and every little bit counts right? I need to do the same thing, but I think when I do I'm just going to replace them with chromoly just for good measure.
Justin
Justin
i did the same thing abouth 3-4 months ago and the same thing happened 2-3 misshift, car shuut off, car ran perfect, and now about 1 week ago there was a bad tapping, turns out about 3-4 pushrods are bent, one so bad its now tapping a vavle and i havent since that one time missed a shift, so i guess they were bent the whoile time becase my mechanic says that the rods have been like that for a while
