Starting car without clutch pedal?
I was wondering if it was possible to start the car without pressing the clutch pedal? I ask because I am waiting on a hydrulic clutch cable to be delivered and wanted to start the car to see if everything is hooked up properly. Any help would be great.
Thanks,
Andrew
Thanks,
Andrew
STF Veteran
No. The clutch pedal depression switch opens the starter relay engage circuit, thereby preventing starting the vehicle with the clutch engaged. However if you were to bypass that switch with a jumper wire, you could easily defeat it. It is located directly and the top of the clutch pedal and has a white threaded stop on it with either two yellow or a yellow and purple wire.
lol just make sure you are not in gear when you start it
STF Veteran
If doing a remote start in a manual, just tie into the purple starter wire downstream of the starter relay at the underhood fuse box. That is the direct 12v signal to the starter solenoid. I don't recommend it, but I've put several remote starters in LS1 M6's including my own. Like said above, don't leave it in gear or else
