LS oil pump Gear
Old 04-03-2014, 11:07 PM
65lsk10's Avatar
Default LS oil pump Gear
Hey guys this id my first LS build and im trying to find out what oil pump gear i need and where i should look to get one... i tried one of my suppliers through work but hes old school and sent me a stock replacement which had the timing sprocket cast to it... i want to install a Cloyes single true roller billet set. I've searched around but haven't found anything except the stocker or a comp cams kit that included it.
Old 04-04-2014, 05:22 AM
BlueMagicSS's Avatar
If the timing set you're looking to run is that much different than the factory setup, it should include the sprocket and oil pump gear.
Old 04-04-2014, 06:55 PM
65lsk10's Avatar
well the problem is the 03 lq4 i have has the timing gear and oil pump gear as one piece
Quick Reply: LS oil pump Gear
