will this fit?
will this fit?
Hey I found a smashn deal on a moser 9" with 4.10s here local. The rear came off a 3 channel abs 97 camaro z28. He is selling it with his brakes and everything still on it. Will this work on my 2000 formula 4 channel abs? idc if traction control works or not
You would have to add the reluctor rings to the axles along with the abs sensors. 3 channel abs only has one abs sensor that reads a reluctor wheel on the pinion gear.
Im bringing this back up because this rear is still for sale and I am considering it. Once again mine is a 4 channel abs with traction control. The rear came out of a 97 camaro. moser 9" 4.10s, 31 spline.
My next question is: will my stock torque arm fit? will my stock drive shaft fit? and what exactly is up with the reluctor ring?
As far as the torque arm goes, I think it should still fit. The driveshaft probably won't work. The reluctor rings would need to be pressed on to your axles. Just swap backing plates over to the 9".
