315's scraping on body. help!
Old 06-11-2014, 09:53 AM
UTSAls1's Avatar
Default 315's scraping on body. help!
I am a proud new owner of a 01 ss that has 315's on and is also lowered (pics coming soon). However I took it to houston this weekend and with two passengers every bump the frame would hit the side of the back right tire. Someone suggested to me getting a pan hard bar or something like that? I took it to a shop to get their opinion but they only worked on mustangs but told me that the tire was also scraping the inside of the frame. any suggestions?
Old 06-11-2014, 01:04 PM
JimMueller's Avatar
Off the top of my head, a combination of things would help:
- Decrease passenger weight
- Increase rear spring rate
- Increase rear ride height
- Perform a thrust angle alignment to confirm the rear end is centered
- If not centered, buy an adjustable panhard bar and correct the alignment
- Roll the rear fender lips
- If you're running rear wheel spacers, see if you can get by using a thinner spacer
- Consider wheels with more backspacing
- Consider a narrower rear wheel & tire
- If the shocks are fairly old or of an inferior quality, consider replacing the shocks
Old 06-11-2014, 09:46 PM
Fry_'s Avatar
Get an adjustable panhard bar and center the rear end.
http://www.foundersperformance.com/c.../Panhard-Rods/
If that doesn't work get out the BFH.
Old 06-12-2014, 09:16 AM
It's not mine! woo hoo!
demonspeed's Avatar
Don't forget new bump stops as I'm sure the stock ones have rotted by now.
And I second the "decrease passenger weight"
Old 06-14-2014, 04:43 PM
99z28monster's Avatar
I had a similar issue however I didn't even need passengers to make contact driving over bumps. First I did the adjustable panhard it helped. Than I rolled the fenders didn't notice any difference which I found strange. So further inspection revealed completely rotten bump stops. Replaced them with the jeep poly bump stops and problem solved. I do make contact now (rarely) over large dips at highways speeds and with other people in the car.
Old 06-15-2014, 07:35 PM
MonmouthCtyLS7's Avatar
Moar BFH...never had a problem.
Quick Reply: 315's scraping on body. help!
