Power steering fluid leak - please help
I've got a slow power steering leak that looks like it's coming from the area circled in the pictures. By slow, I mean it only needs to be topped off once every few months. Is this something a noob like myself should be able to fix, or would I be better off taking it into a shop?
If it's an easy enough fix, could someone please explain the process to me? A link to step-by-step directions would be equally appreciated.
Thanks
Thanks
Are you sure that is where the leak is coming from if so it should be pretty straight forward by just tracking the line and replacing it not to much of a step by step. I had the same problem I thought my leak was coming from a line when it was actually my rack and pinion which was a much harder fix.
To be honest with you it couldn't hurt to just let the fluid drain and then just refill it probably be the fastest and easiest way to go about and the fluid is cheap enough not to hurt the wallet.
If you're a noob, or just someone who is not very mechanically inclined to work on cars like I am, it might be a good idea to take it to a shop and let them replace the hoses for you. You can save money by buying the parts yourself and then just paying a shop for the labor.
