Will not stay running
Just bought a 98 WS6 that has been sitting in a garage for 5 years and started rarely. As long as you keep the starting fluid going it runs great, after that it will die. Any ideas what to do next. I assume its in fuel system.
Run a cleaner through the fuel system to clean the injectors. Add 1oz of penzoil 2 cycle synthetic motor oil for every five gallons and lube every thing up on the top end. Methanol dries out all the rubber seals. Won't hurt the sensors
If you have another person to help, have someone underneath the fuel tank. Make sure the key is in the OFF position. Next turn the key to the ON position but don't start it. The person underneath should hear the fuel pump whine on then off. If they hear nothing, check the fuel relay or replace the fuel pump. If they do hear the whine, then its possible you have a clog some where in the fuel sending line. Hope this helps.
