is a patent # consistent with all product? fast 92 question
looking to pick up a fast 92 intake manifold but the logo has been removed. only numbers are the patent numbers on the back/bottom of intake.
revision "J"
7021263 B1
Im wondering if its a true fast 92 intake or not.
revision "J"
7021263 B1
looks to be like a 2 piece. bolts up front and back and under. looks like a fast 92. even has the indentation on runners.
4 bolt and measures up to about 92mm opening.
ill see if i can post pic.
Edit: I just found an ebay seller with large pic that shows that exact patent #.
must be the same fast then im assuming?
also since its a 2 piece can it be taken apart without needing special glue to put back together?
guy blew up his motor so it will need thorough cleaning.
