Tcs/ASR wont come off
Hello i need help with my camaro when i first bought the car the asr switch was not there it just had the blank cover on it but after i poped the cover i found a sensor just there next to the fog light switch and i was thinking it does have tcs because when i turn on the car i see the ASR light come on and right off and the low trac light as well so i went to buy a switch but still doesnt come off why
Sorry if its a dumb question
When i do race my friends my low trac light comes on and she feels like she loses power
LS1Tech Administrator
Received 1,462 Likes
The traction control module is located in the engine bay, right behind (and slightly above) the battery and is mounted to the shock tower. You will be able to find it easily because there will be cables running between it and the throttle body.
If you do not have that module in the engine bay, then the car does not have traction control.
I'm sorry if I am asking something dumb but do u have a picture of how it looks I read other people talk about this and they always point to a module on the driver side In the front of the engine bay I think it is the abs module I read that it had something to do with the TCS.
https://ls1tech.com/forums/generatio...on-00-ws6.html
You should also have a switch that looks like this on your console:
http://www.ebay.com/itm/97-02-Firebi...-/171403874062
I gave you a picture of the Camaro engine bay with TCS/ASR. The switch picture is from a Pontiac, not sure if the Camaro looks the same, but it should be in the same place.
Also, if you have this system on and you spin you rear tires, like doing a burn out or on gravel or whatever, you will feel your gas pedal kicking back at your foot giving you haptic feedback. It is pretty obvious when it happens.
