headers or convertor
this shouldnt be a poll,
wtf is this, ls1.com?
instead, how about some info?
header pro- faster by .2-3, louder
header con- louder
verter pro- faster by ~.5
verter con- looser throttle feel depending on stall speed
now make your own opinion.
header con- louder
[QUOTE=Stone0fFire].......header con- louder....QUOTE]
That's not a con!! I'd say converter as well, I regret getting headers first, as long as you can at least a cutout or catback get a stall first.
Installing a converter really isnt that bad I just did one I had a few issues but only because of trying to hurry. Just do yourself a favor and go and buy a 13mm and a 15mm "swivel socket" and a couple really long extentions my only hang-ups were the dipstick bolt (15mm swivel-socket made that a snap) and I dropped the y-pipe and in doing so I broke off one of the studs on the flange. A local shop quoted me $350 for a converter install, no way, its no where near that hard. I say go for it theres plenty of info on this site (a4 section) and if you have a problem just post it someone will help ya out. Hope this helps good luck oh and I vote converter and dont be afraid to go big!!(3500+)
Originally Posted by mako22
everyone yelling verter - can you lay out the costs for us on:
Verter itself
tranny cooler
drag radials
installation
I come up with around $1500 easy right?
Verter itself
tranny cooler
drag radials
installation
Jet-Hot LT's $512, Speed Inc True Duals $550. (installed headers myself) Doing it this way if you already have a cat back you can sell it and no need for Y-pipe. Total cost: ~$1,100
TCI SSF 3500, TCI trans pan, tranny cooler, basic tune, Trans Go shift kit, installation of all parts by prof speed shop (ls1 speed) will be ~$1,380.
That is $280 more for converter than Headers/duals to axle. If I had paid for the header install that would have cost more than the conveter will. I won't count drag radials, I think those should be purchased anyway. (I got some before I got headers, even) They really arne't far apart, and depending which route you go, what you already have, etc, either one could cost more than the other.
Moderator
With a stock converter and stock transmission
programming, you will spend an awful lot of the time
operating where headers don't help you.
I would skip the shift kit, and buy your own tuning
software. TCI3500, $500. HPTuners, $499. Trans
cooler, $49. Install (converter only, do the rest
yerself) $200-$300. About the same price, but
now you have the authoritah.
Header cons:
Longtubes hang pretty low...
No Cats (unless you get a catted Y)
w/o Cats you'll need a tune or O2 sims.
Loud? Louder than you think!
Installation on Longtubes... Not fun.
Did I mention how low they hang? (my car is lowered 1")
And FYI: Programers suck - Pay someone to tune using LS1 Edit You can get major HP gains throughout the RPM's. Plus delete rear 02's, change fan settings, etc...
I have SLP Longtubes, probably the lowest hanging brand out there. The car is a little louder than I expected even through a mufflered catback (Magnaflow). Installation wasn't all that bad, but tightening the bolts... n:
Just my $.02, but what do I know???
I ran DR's and launched at 3000RPM all the way to 5000RPMs. I also must have made 30 passes last year like that. She's still in one piece. I think the combo of 4:10's and DR's is a time bomb, but the stock 10 bolt should be able to handle up to 350RWHP (or a little more) on stock gears. However, I do agree, the rear is the weakest link in our drivetrain. Damn S10 rears...!!!
imo i am saving up for headers myself probably the qtps with cats instead of the coverter b/c i plan on port/polishing my heads and getting a cam eventually and when you get a cam you need to match it with your converter so why get a coverter now if you plan on getting a cam? that is my reasoning why I am going with headers first. and btw a tranny cooler should be a must if you have an auto and plan on racing it because the autos in ls1s are not the best heat is the trannys worst enemy. I did the tranny cooler way early in my mod list. just my .02cents
