Rockers Arms
Comp Cams have an ultra gold rocker set for my LS1, the stock ratio is 1.7 and theirs is 1.72 . I will be installing a LG Motorsport G5X3 cam , .600 intake and .610 exhaust lift . Comp told me that I would see .607 and .617 with their rockers . Thank you for the formula to check out their numbers . I knew that the numbers would change , but I did not know by how much .
The numbers Comp Cams gave you are correct, just rounded down to the nearest 1/1000th.
.600" valve lift divided by 1.7 = .35294", multiply by 1.72 = .607"
.610" valve lift divided by 1.7 = .35882", multiply by 1.72 = .617"
IMO, I'd just stick with the stock rockers.
Thank you , I am keeping the stock rockers and installing a comp cams trunnion kit .
