Best "cam only" max performance cam
Old 09-11-2014, 01:55 PM
renee00formula's Avatar
Default Best "cam only" max performance cam
Hi guys! Sorry for the lame post but it's been years since I've been around ls cars. Back then the big cams were the Trex and MS4. What is the biggest cam out there now that will clear stock valve and piston ls1s?
Thanks!
Old 09-11-2014, 02:06 PM
HCI2000SS's Avatar
Well the stock valves haven't changed so that's still about as big as you can go lol
Old 09-11-2014, 02:07 PM
I figured in the last 4 years maybe someone did something different is all
Old 09-11-2014, 02:15 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
The Brian Tooley Racing Stage IV N/A camshaft would be my cam of choice. I have personally seen this cam make some ridiculous power with good drivability. Here is a link to it directly off the Brian Tooley Racing website:
http://www.briantooleyracing.com/nat...-camshaft.html
One car I setup with this cam made 420 RWHP to the tires through a TH400 and 9" rear end with a spool. Besides the badass power that the car made it also has very good drivability and can really be driven anywhere.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 09-11-2014, 02:20 PM
Thanks for the info! I'll check it out!
Old 09-11-2014, 03:42 PM
Rise of the Phoenix's Avatar
TRex, MS4, Tsunami, FMS Godzilla, Ed Curtis/FTI Hellion cam, Polluter, Vindicator, etc. Take your pick. Just make sure you have full bolt-ons and a damn good tuner, or else you'll be hating life.
Old 09-11-2014, 03:44 PM
I'm familar, we had an MS4 car prior. Just getting back into the ls1 world and was curious what's out there. Thanks for the reply!
Old 09-11-2014, 05:48 PM
ULTIMATEORANGESS's Avatar
Smile
perhaps a local tuner can make a custom cam to fit your needs.
Old 09-16-2014, 12:00 PM
redtan's Avatar
The function of the 4 cycle engine hasn't changed in 4 years. In fact, the LS1 itself hasn't changed in 4 years. So why would you think the cams that make the most power would have changed?
So while the specs of the cams haven't changed much, doesn't mean that the cams themselves haven't. There's a slew of different lobes floating around the internet that make just as much power (if not more) than the previous lobes you were around back then and are easier on the valvetrain and quieter. That's where the "tech" went, not the duration of the cam.
Old 09-16-2014, 12:23 PM
ragtopz28's Avatar
^^Yep^^ I know the car of which he speaks. It definitely likes the juice too!
I went with the similar BTR Stage III
Old 09-16-2014, 06:20 PM
Wes_33's Avatar
I like the Vindicator from Vengeance. Great power under the curve for a cam that size.
Old 09-22-2014, 05:54 PM
godawgsdv8's Avatar
My motor is all stock. I want to give it a little more power. Already looking at headers and exhaust. Is replacing the cam the right way to go or is there some other things I need to do first?
Old 09-22-2014, 06:47 PM
Furious1's Avatar
Auto or manual car? If auto you will need a stall and a trans cooler. Also, you will need supporting mods to go with the cam...lifters, springs, maybe oil pump, etc. That said, yes a cam is a logical direction to go next after full exhaust/bolt on's.
Old 09-22-2014, 07:04 PM
godawgsdv8's Avatar
It's auto. I'm looking at headers, x-pipe, 3" all the way. What stall do you suggest? Trans cooler?
Old 09-22-2014, 10:54 PM
studderin's Avatar
https://ls1tech.com/forums/dynamomet...nly-setup.html
Old 09-23-2014, 06:47 AM
MonmouthCtyLS7's Avatar
Like the polluter here. All good choices mentioned though.
Old 09-24-2014, 10:12 AM
SJFGTO's Avatar
Do the exhaust first. You will need a stall, size will depend on your cam selection. Do not skimp on a tranny cooler either, that will be a must.
Quick Reply: Best "cam only" max performance cam
