LS1 Engine noise help!
Old 10-04-2014, 09:18 AM
Camaro4Lif3's Avatar
Default LS1 Engine noise help!
Just a shot in the dark hoping someone has had this happen specifically in a 4th gen. When my 2001 SS M6 is on and at idle out of gear I can rev the motor and I don't hear anything out of the norm. When I'm in gear and put a load on, I hear a clanking sound that sounds like it's coming from the left side of the motor. It won't do it out of gear but will do it in gear. I don't feel like it's my tranny but who knows. Other then the sound no performance issues. To me it sounds like the rockers are clanging on the valve covers but I'm in the car and can't produce the sound out of the car especially when it only happens when accelerating. Once I steady out it not audible.
PRC Stage 2.5 5.3L heads ported and polished. Double spring with LS6 Lifters
Torquer V3 Cam
FAST 35lbs injectors
LS7 Clutch
KOOKS LT Headers
High flow cats and catback
Old 10-04-2014, 01:19 PM
ULTIMATEORANGESS's Avatar
did you look under your car for anything loose or broken?
Old 10-06-2014, 11:11 AM
idahoz28's Avatar
Check the torque arm bolts at the rear differential and transmission.
Old 10-06-2014, 05:30 PM
Mercier's Avatar
And transmission mount, motor mounts, exhaust. Hopefully something for the "external engine" section.
Old 10-16-2014, 04:09 PM
spent21's Avatar
engine ping/detonation? do you have any way to data log?
Old 10-17-2014, 05:52 PM
Forcepower's Avatar
how many miles? It could possibly be a wrist pin.
Quick Reply: LS1 Engine noise help!
