Will this AC compressor fit my engine?
Old 10-30-2014, 10:37 PM
boostmonkey's Avatar
Default Will this AC compressor fit my engine?
Greetings all,
I have an 02 Camaro Ls1 I am putting into a project car. I have the AC bracket, but no ac compressor..found a great deal on some "new old stock" part number 25821958, PN cross references to a 2003-2010 Chevrolet Silverado GMC Sierra and the seller says it is listed as for a compressor for a 04-08 cadillac cts -v ls1. If I have the correct bracket for my engine, will this compressor fit..are all the Ls1 AC compressors interchangeable?? Thanks for the help...
BM
Old 10-31-2014, 12:45 AM
Fry_'s Avatar
No.
Also what are you putting this into, the low mount AC compressor doesn't fit most applications and would require notching the k member.
Old 10-31-2014, 05:01 AM
Default compressor
Not concerned about the k member, there is not one being used for this application. So this will simply not bolt up to my block is what you are saying?
BM
Old 10-31-2014, 12:45 PM
toms57's Avatar
I have been told that the factory compressor will NOT work with Vintage Air and similar aftermarket systems. Check with the mfg of the system you are using.
Old 10-31-2014, 01:18 PM
Fry_'s Avatar
BM
Might bolt up but probably not and the pulley wont line up with the belt. CTS-V uses the short belt spacing from the block, and trucks use long belt spacing, f-bodies are between the 2. Just out of curiosity what kind of car doesn't have a k member or engine cross member of some kind.
Quick Reply: Will this AC compressor fit my engine?
