Supercharged 404 Build
Just getting started building an LS2 that will be going in a 2001 camaro SS using livernois 404 cid stroker kit, D1SC pro charger, TEA stage 2 243 heads. Peak Speed extreme port job on LS2 intake with a 102 mm throttle body. Will be posting pictures and modification shortly. A big shout out to vengeance racing as they have been instrumental in supplying parts and expert advice, will keep you posted in the following weeks!
https://ls1tech.com/forums/attachment...1&d=1416364798
These are some issues we ran into while putting the short block together. We had to clearance the block for the Manley H beam connecting rod bolts.
Even though the ross piston were clearanced for the reluctor wheel there still was inadequate clearance on number 8 so we had too do some additional clearancing so no contact would acquire.
Installing the Ross supercharged pistons after filing to the rings to .24 and .26 on the second.
Photo of 404 stroker crank installed using arp main studs with bearing clearance on average of .0022. Rod bearing clearance of .0023
Comp camshaft installed using cloyes hex adjust true roller LS2 timing chain and gears. Custom camshaft specced by vengeance racing with .620 I lift .615 E lift
duration @ .050 235 I and 242 E with a lobe separation of 114.
