just bought an 02 ws6 what is this under the car?
hey im new to the ls1 world bought an 02 trans am ws6 with 105,000 on it. i just have a few questions for u guys if u could help me out.
1. what the heck is this (see below) guu said it was a transmission stabilizer or something? all i know is that it moves and i can hear it knocking when i go over bumps
2. how do i know if it has a shift kit in it? it shifts kinda hard from 1st to 2nd. yes i checked the trans fluid while it was running and warmed up.
3. i just want the car to last, not really trying to *** any performance mods or anything.....yet..lol. anyway wat are some things i should be looking out for in a used ls1 and 4l60e trans?
the picture is the torque arm and looks like it has the chassis mount. both parts are aftermarket and a good upgrade. as far as the clunk when hitting bumps, it could be the arm could be hitting the body or something suspension related.
if the trans has a quick and solid shift then it probably has a shift kit in it.
look up chassis mounted torque arm. looks like you have the shorter version. it gets better 60ft times at the strip but not as good when dailying.
well piston slap is pretty common on ls1s. its not harmful to the motor. just be sure thats what the noise is. ls1s also have a noisey valve train. many say it sounds like a sewing machine. post a video of a cold start up so we can see what the sound is. as long as the oil pressure is good and you change the engine/trans oil and other fluids at the correct intervals, you will be fine. just do alot of reading and research on the motor and trans and educate yourself. there is alot of info
http://umiperformance.com/catalog/index.php?main_page=product_info&cPath=7_115&produ cts_id=209
This may not be the exact brand, but this is the part that you're looking at. Piston slap on cold startup is fine, as long as that's what it really is. Like he said, post a video so we can listen.
If torque arm is moving and knocking then check the rubber bushing that holds torque arm to tranny. I had same issue on my slp torque arm, it would knock hard anytime i hit the gas. Couldn't find the bushing online but i called either jegs or summit ( can't remember which one ) and they were able to get one to me.
