1999 TA no power??
It could be clogged. Also try a compression test to see how all the cylinders are holding compression. When you changed your plugs did you change the wires and the coil pack?
so i had an idea and while the car was running i unplugged the coils one at a time and the engine tone changed each time...hows this possible with a cold cylinder?
Hmmmm. Im thinking maybe one or two injectors are not spraying everytime or not enough fuel. Try a compression test maybe you have excessive blow by.
I will have to get a compression gauge as mine needs Schraders but if i had excessive blow by wouldn't it smoke oruse oil?
I believe its possible. How about your throttle body and intake are they clean? Your throttle body might be dirty and be alittle clogged. Check your airfilter as well. You said before ses light was on check the codes.
throttle body is clean and i have a brand new k&n filter. I dont think the motor is healthy. Ive been wanting to build a stroker for a while guess its about time....lol
#33
#34
#37
As far as power no clue never been tuned or dynoed to my knowledge. If i had to guess seat of the pants 250-300 my lt car was dynoed at 330 to the tires and its not even a close race my wife drove the lt car in drive letting the car shift and pulled me 2 to 3 car lengths before it shifted to 2nd
None car doesn't smoke rattle or knock just no *****. Im thinking it needs a tune but dont want to waste the money as i plan on h/c/i mods in the future Which will require a tune then as well. Im almost thinking it needs a motor?? ive always been amazed at even stock ls1 cars at the track but needless to say very disappointed in this one
#40
