In need of help with my engine build 5.7 block swap to 6.0 but still use 5.7 ls1 top
So I threw a rod thru my 5.7 block on my 2000 ss camaro slp car 130,000 miles so I found a 6.0 out of a 2005 chevy Silverado I'm just wondering will I be able to use my top end from my ls1 knowing a rod shot thru the side of the block? Need info asap don't wanna spend money 1000x sort of on a budget build as of now wanna just swap the blocks out how many horses am i looking to get with a Ls1 top end with a lq9 6.0 block
Kool so that means all I have to do I take all my top end pieces and remove the 6.0 heads to the 241s I have on the ls1 intake fuel rails etc shouldn't have to tear the block down for modification right ?
I had someone on here tell me you have to run the truck accy drive if you swap to a 6.0 truck motor not sure if this is true i am thinking of doing the same swap as you as mine just dropped a cylinder
So is it safe to say with the 6.0 after I change top end to ls1 I should have a pretty good amount of power even with out throwing a cam on there just yet right knowing the 6.0 has more compression then the 5.7?
So the build is in the making 241 heads resurfaced and ported ls1 intake 95 mm tb 90 mm intake everything else is stock wondering how much stock power i should have b4 putting cam kit with new lifters and pistons will i have at least 340bwhp
So I just picked up a 5.7 04 gto engine with 241 heads ls6 cam ls1 intake stock TB everything else stock except tune it's not finished yett but will it lobe like a muscle car with a cam I'm buying it rebuilt from the CHEVROLET DEALER WITH NEW PISTONS BEARINGS CYLINDER HEADS BASICALLY REBUILT WANNA THROW a pcm tune on after engine gets put in will I need the tune to notice greater hp gains
That cam won't have a choppy idle at all but it will make a little more power than the stock cam. Will you be running an aftermarket exhaust or any other bolt on mods?
Well it has flowmaster exhaust with an election cut out on it other then that the pcm has been played with but once I put blew gto engine wit ls6 cam I'll have to do a tune any way right?
Will I b able to switch the cam out further down the road for a real choppy cam that's gonna lay down lots of performance to the Rea wheels
