need some help building a motor
okay guys i need some advice. this is my first pushrod build.
it's going into a 1991 nissan 240sx. dont worry did all the work to handle a little more weight. here is the motor i picked up lm4 leaving it stock with the exception of ls1 intake.
Now there is not a lot of info out on this motor. what kinda numbers do you think this motor can handle in stock form. whats going to be a weak point of it?
What i plan on doing is 799 heads with dual valve springs, valves, port job, and a mild cam.
Over the winter i wanted to do 5858 twin turbo setup but wanna make sure the block will hold like 650hp. and advice is appreciated.
Welcome.
What heads are on the motor now ? Do you plan to forge the bottom end for your turbo project or run it stock ? The block and crank will handle 800+ hp, rods and pistons will be the weak link. You could push the stock bottom end to the 600 hp mark with some good fuel and a conservative tune. What other info are you looking for with this motor ? Biggest difference the LM4 has VS the other 5.3L LS motors is the oil pan made for the 4WD SUV's. Other than that it's pretty much the same.
