Coil packs?
Old 06-03-2004, 12:50 PM
soldier6552's Avatar
Default Help walk me through installing my LTs please
What are coil packs, I think I know but I'm not possitive.
-JOSH
Old 06-03-2004, 12:56 PM
chupr0kabra's Avatar
They are the doohickeys where your spark plug wires attach. One end on the plug, the other on the coil pack.
I ARE TECHNICAL!!!!
-Mike
Old 06-03-2004, 01:02 PM
STF Veteran
TA TED's Avatar
In distributorless ignition systems, they replaced the old cap and rotor. It's GM's way of attemting to repay us for that f$%^ ing optispark. Based on commands from the PCM, they provide the energy for the spark plugs to fire.
Most newer vehicles will have them instead of rotors most likely due to reliability, lower maintence costs, etc..
Old 06-03-2004, 01:07 PM
VoodooWS6's Avatar
The are located on your valve covers. They produce spark to you spark plugs. A new version of a distributor.
Old 06-03-2004, 01:34 PM
Thanks guys, thats what I was thinking too but I wasnt possitive. So far I have the driver side manifold off but the passenger side is a total bitch. All but 2 bolts have been removed from it, and I'm struggling with the last two. Any Ideas or advice on this would be greatly appreciated. Thanks again for the help fellas.
-JOSH
Old 06-03-2004, 01:35 PM
Oh and the 02 sensors things confuse the crap out of me, what do I take off???
Old 06-03-2004, 01:52 PM
Copy & Paste Moderator
VIP1's Avatar
What do you mean?
The O2 sensors are in the exhaust tubing, not on the engine.
If you are looking for them, look for a connector going into a device stuck in the side of the exhuast pipe. There are 4 of them. One in front of each cat and one behind each cat.
Old 06-03-2004, 02:12 PM
Do I remove them from the car or just the pipe?
Old 06-03-2004, 02:13 PM
The dip stick is in the way of one of the header bolts, how do I get it out of the way?
Old 06-03-2004, 02:23 PM
NOBR8KSS's Avatar
A 1" or 1.5" extension will help you tremendously when working around the headers.
Additionally, you will need to remove the oil dipstick tube by removing the bolt at the top and then unseating the tube from the oil pan. You will have to give it a pretty good tug to get it out, but it is just kind of "snapped" into a hole in the oil pan with a rubber o-ring.
For the front O2 sensors (before the cats) you will need to unbolt them from the exhaust and just place them out of the way for reinstallation into the new header. For the rear O2 sensors, if you are using high-flow cats in your new exhaust, you can reuse the rear sensors. If you are removing the cats (off-road y-pipe) , then you will need to replace the rear O2 sensors with O2 simulators and then zip-tied up out of the way. Then you can save the rear O2 sensors to replace the front pair when they start to foul out.
Old 06-03-2004, 02:39 PM
technical's Avatar
I ARE TECHNICAL!!!!
-Mike
NO, I ARE TECHNICAL!!!!
Old 06-03-2004, 03:35 PM
My damn dip stick tube WILL NOT pull out? Ive struggled for a damn long while on this. Any ways around it?
Old 06-03-2004, 03:54 PM
jrp
SN95 Director
jrp's Avatar
what are you trying to do?
Old 06-03-2004, 04:25 PM
4 beers later it finally comes out . I'm in the process of installing my Kooks LTs finally and it was stuck on my passenger exhaust manifold (I come ask a question everytime I hit a tough spot). I got it out though and now the car is ready for the install. Unfortunatly I have to work tonight so it will have to wait until tomarrow . Thanks for all the help so far guys.
-JOSH
Old 06-03-2004, 04:33 PM
The guys at Auto Zone didnt know what NGK TR55s are so I got ACDelco TR55s. What are they exactly or are these ones good enough?
Old 06-03-2004, 05:28 PM
So you are! I stand corrected!
-Mike
Old 06-03-2004, 08:03 PM
locosteelersfan's Avatar
Strictly from what I have heard(may be total BS) but
NGK55 at some point became factory but use the ACdelco
name. I don't know how much I believe that considering
GM says stock plugs are good for 100K(that's another agruement)
Old 06-03-2004, 11:13 PM
VIP1's Avatar
Sorry for the delay in responding, but NOBR8KSS covered it.
Old 06-04-2004, 01:57 PM
Well I went ahead and got the NGK ones online so they should be in tomarrow. Unfortunatly that means no more work can get done today but I will keep updating tomarrow on what I encounter. Thanks for all the help so far guys.
-JOSH
Old 06-07-2004, 11:51 AM
Got my sparkplugs in today so Im hoping to finish the job. Just to clarify, do I need a torque wrench for anything on this install?
-JOSH
